  • July 09, 2025, 07:40:19 AM
Author Topic: Engines cutting out!  (Read 4973 times)
Offline Andrew Tinsley
« on: December 02, 2013, 10:32:37 AM »
  I am a bit reluctant to ask this question, but it is so weird that I can't think of a cause. Basically I have a friend that has been flying stunt for more years than I care to think. He is an expert at F2b, only advancing years restrict his scores. So he is no fool at setting up engines for stunt.
BMFA Number 64862
Re: Engines cutting out!
« Reply #1 on: December 02, 2013, 10:54:14 AM »
  Whoops! I must have pressed something wrong! To continue, he has had 4 planes cutting out after about 2 minutes flight time, regular as clockwork. He has changed the obvious like fuel and plugs to no avail! Tanks have been changed, uniflow, basic stunt tank and R/C clunk tanks have been tried and props have been changed too in desperation. These planes flew well last year, but a complete washout this year. My friend has gone electric in sheer frustration and swears he won't go back. Even his LA 46 is giving the same problems!
  All a bit academic now, but is there a common cause that has been missed or is it just 4 different obscure problems? I am out of ideas!
Andrew.
BMFA Number 64862
Offline Peter Grabenstein
« Reply #2 on: December 02, 2013, 11:23:29 AM »
Did he ever change fuel for a fresh and clean mix ?.
Does he mixes  and filters his own fuel ,because tiny little Castor oil parafin flakes.
Maybe the Methanol barrel has been soaked to much moisture/water over the month/years.
Could be a water/moisture prob.(in low percentage) which causes overheating and flame outs.
Just my thoughts.
Peter
I hate pessimists, I prefer optimists.
Impossible is done immediately, miracles take longer.
I don't care who your father is ......... as long as I fly here,
Nobody walks, runs, floats or flies across my circle ......... not even to fetch fish, wine or bread.
« Reply #3 on: December 02, 2013, 11:38:53 AM »
Peter could very well be correct...however it's really impossible to diagnose a problem like this that occurs over a period of time with different engines and different airplanes...obviously fuel could be a common denominator if he continued to use the same fuel.  If he is an experienced F2B Expert it is unlikely that he wouldn't know this and try some different fuel.  It could also be as simple as a bunch of bad glow plugs...any idea what brand of plugs he uses, and are they all the same brand.
Another possible common denominator would be bad fuel filters that leak after a while...
Very strange phenomenon.
Maybe he just wanted an excuse to switch to electric!!! y1 LL~ LL~
Offline Phil Krankowski
« Reply #4 on: December 02, 2013, 11:40:27 AM »
Excess varnish can cause a similar symptom in some engines, but 4 at the same time is odd.
Phil
« Reply #5 on: December 02, 2013, 11:40:44 AM »
Kinda what Peter said.  I'd be looking for what he's doing that's different from previous years and/or from other folks, and what's common to all the planes.
If his electrics start cutting out after two minutes this coming year, I'd suggest a ritual involving a pagan shrine, a chicken, and a sharp knife.
« Reply #6 on: December 02, 2013, 12:02:30 PM »
 LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~
« Reply #7 on: December 02, 2013, 01:02:32 PM »
Hi Tim,
That is why I was a bit reluctant to ask about this weird behaviour! I know I am asking for a good ribbing! My first thought was fuel and he assured me that he swopped to fresh fuel as soon as he started to get the problems. He is (was!) using hot OS plugs (I think No 7 from memory). He has tried different brands of plugs since, including my favourite Enya No 3 plugs.
  What is getting me wound up, is that there is no problem with starting and the planes fly as they should until the engine cuts. The 2 minutes flight time isn't gospel, but flights average out at this sort of level before the cuts. I know that my question is about as precise as "how long is a piece of string" . No one can analyse the problem at a distance. I just thought I would ask around to see if I had missed something obvious. Strange thing is that the planes will run out a tank on the ground with no signs of the problem. It is one of the oddest things I have come across in 60 years of control line flying. Maybe someone has been sticking pins into clay models of his planes!
Andrew.
BMFA Number 64862
Online Perry Rose
« Reply #8 on: December 02, 2013, 02:00:43 PM »
Does he have the tanks plumbed properly? Maybe the feed and vent lines got switched.
« Reply #9 on: December 02, 2013, 03:07:50 PM »
  What does it sound like as it is quitting? Rich, lean, like a switch? What maneuver is in progress (if any)?
Offline Chris Wilson
« Reply #10 on: December 02, 2013, 04:00:18 PM »
Hi Andrew,
                  if your friend is only getting a constant two minutes 'out' of 4 completely different setups then look for what constantly puts those two minutes 'into' them.
Does he use a common syringe to fill the tanks? Is it being filled with only enough for a two minute flight by mistake?
MAAA AUS 73427
« Reply #11 on: December 02, 2013, 04:34:46 PM »
Thanks for your suggestions Ty and Perry, tank plumbing has been checked time and again. Tanks have been changed too, even going back to old fashioned simple stunt tanks of yesteryear!
Brett, that is the really odd thing, the engines ran perfectly normally, neither rich nor lean, they simply cut as though someone had turned an "off" switch. The only obvious connection between these recalcitrant engines is, I assume, the fuel. Fresh fuel from the same manufacturer was used as a first stab at the problem and when that didn't do any good another brand was tried. They were all 5% nitro and 22 to 25% oil (half and half castor / synthetic).
  The chances of 4 separate engines having unconnected problems which gave the same symptoms is remote in the extreme and yet if the problem stems from the same source, what could it be?
  Do you ever get the feeling that it might have been better to keep quiet about such odd behaviour? The obvious inferences are that one is either a knave or a fool!!!!!
Andrew.
BMFA Number 64862
« Reply #12 on: December 02, 2013, 07:31:01 PM »
  I have had individual engines do that from time to time, one particular engine would do it over and over even on the test stand. The only solution I ever found was the fuel. Byron fuel, in particular, was like a magic cure-all, that was the only fuel it would run on.
« Reply #13 on: December 02, 2013, 08:04:56 PM »
I had a Fox 35 with a tongue muffler that would quit every time I came out of the outside loops and leveled off. I tried everything I could think of and out of frustration I was changing engines when I noticed most of the holes in the muffler were completely plugged with carbon. Cleaned out the holes and all was good.
« Reply #14 on: December 03, 2013, 04:43:19 AM »
Thanks Everyone,
  A lot of interesting suggestions there. No I don't know if the same syringe is used on all 4 models and again, I don't know if there is a senior moment about using too small a syringe which is only good for 2 minutes or so. Come to think this may well be a reason! After the engine quits and the plane lands , you can restart the engines no problem. Now can I remember if the plane was refuelled before the restart? no I can't so let me ask the question. I think that something like this must be the answer, otherwise it is too weird to contemplate!
Andrew.
BMFA Number 64862
« Reply #15 on: December 03, 2013, 12:47:23 PM »
Thanks Everyone,
Andrew.
   He's not using Rossi plugs, is he?  Those are exceptionally prone to this issue. Ted discovered that the hard way,
« Reply #16 on: December 04, 2013, 02:36:50 AM »
Thanks for that info Brett, I will get back to him and ask the appropriate questions, I really would like to find out what is going on. Maybe I can make him an offer for his stunt engines, someone has to get something out of this odd situation!
Andrew.
BMFA Number 64862
John Leidle
« Reply #17 on: December 04, 2013, 01:31:38 PM »
   I have had a few engines that run fin on the ground, after launch they are still ok, then about the square 8 they go rich,,, I'd like to know the solution or at minimum the problem.  A ST .51,  Double Star .54 ( which is fine now) & one of my PAs . The PA only does it with a certain fuel  never any other time.
« Reply #18 on: January 21, 2014, 04:17:36 PM »
Andrew,
I understand this is a frustrating problem, I think the common thread is the fuel. I assume that these ships were flown before and didn't have this problem. Sometime you can get a batch of fuel that is contaminated with something that causes all kinds of issues. You didn't mention what brand of fuel he is using. I think it is worth trying some SIG 5% or the Byron helicopter 5 or 10%. These are know high quality brands and would eliminate one possible issue. Also, if these engines have some time on them have him remove the plug and turn the engine through the compression stroke to check for excess tightness (if an ABC should be a little pinch near the top of the stroke). If it is very tight there may be some varnish that needs to be removed (it seems unlikely that the four of them all have the same amount of varnish). Last clean out the needle valve spraybar. Keep us posted.
Best,       DennisT
« Reply #19 on: January 23, 2014, 03:28:10 PM »
Hello Dennis,
Fuel was the first thing that was changed, There are several reputable fuel blenders in the UK and I know they have all been tried in turn, including some home mixed fuel. Varnishing isn't a problem as the engines are run on half castor and half synthetic and show no trace of varnishing.
Thanks for your thoughts,
Andrew.
BMFA Number 64862
« Reply #20 on: January 24, 2014, 04:46:54 AM »
Hello Everyone.
The problem has been found, there is a huge amount of very strange goo in the silencers. It isn't the usual sort of rubbish one gets, but some very odd bubbly looking stuff. This has been restricting flow no doubt. Now how did it get there? Well my theory is that the engines were not put away properly for the winter.
  My friend's usual technique is a bit idiosyncratic. He first puts in a good amount of air tool oil and works this around the engine. he then puts a small amount of fuel in the tank and lets the engine run until fuel is exhausted. He then works in another good dose of air tool oil and that is it. Quite why he does it this way. I have not got a clue. He is over 80 and has always done it this way, with excellent results.
  My theory is that he put in something else rather than air tool oil. This has reacted with the normal castor goo in the silencer and the witches brew bubbled up, giving a restriction in the silencer. Once it is cleaned out, then the engine run returned to normal. If I am correct, then I don't have a clue what it was that he put in the engines. There is a fair selections of bottles and cans in his workshop and it could have been any one of them, in a senior moment. I am surprised that the engines would restart easily after the two minute run, but then there was no rush to get airborne so maybe they cooled sufficiently to restart? Still a few queries as to the why and how, but the problem has been nailed.
  Oh yes I checked engines and bearings and there appeared to be no damage to anything, so he looks to have got away with it!
Thanks for all the helpful suggestions, I was somewhat reluctant to post this one because it was a "how long is a piece of string question" and wasn't sufficiently defined! Oh by the way The glow plugs are new Enya 3s, the original plugs were tried and they were not very good. They dropped substantial revs when the glow lead was removed and a trial flight with one of them produced a bit of a faltering engine run. So maybe the liquid X didn't do a lot for the plug. Probably a case of a poisoned element too? Strange that the "two minute" flights appeared to be normal. The plug problem wasn't noticed at the time and that is strange too. Maybe we were not as attentive as we should have been.
Andrew.
BMFA Number 64862
« Reply #21 on: February 22, 2014, 06:43:08 PM »
Andrew, I don't see how the gunk could have gotten from the muffler into the engine. Even with muffler pressure, that's not going to happen, because there is only as much fumes going into the tank as there is fuel flowing out. As to the glowplugs, it's not unusual to have last season's glowplug not work very well (if at all) for Spring's first flight. Some sort of corrosion, perhaps, or maybe it's the seal and not the filiment? I've had it happen, but then the next Spring, no problem, so I've come to the conclusion that it's just one of those things that happens. Sometimes!
I generally give my "used, but still light up, but don't seem to work right" glowplugs to Tim Wescott.  ;) Steve
« Reply #22 on: February 24, 2014, 01:56:02 PM »
Hello Steve,
I think you either misread what I wrote or maybe I wasn't too clear in my explanation. The problem was that the mufflers were obstructed with some sort of bubble infested goo! I have no idea what it was or indeed how it got there. My mooted explanation was just that .......mooted ! I have never seen anything like it in nigh on 60 years of power modelling. At least there is a common explanation for the strange behaviour of several engines quitting after a few laps. Quite what the messy goo is and where it came from is still an unanswered query!
Andrew.
BMFA Number 64862
« Reply #23 on: February 24, 2014, 06:39:51 PM »
Andrew, I understood what you wrote. I wanted to clarify that the goo was not going through the engine, but clogging the exhaust. Sounds like time for the crock pot and antifreeze treatment...
The glowplug problem may be related, or not. But I tend to think that the glowplug is just one of those things that can go bad for a variety of reasons. When Spring comes, I would suggest getting the engine started with the old glowplug, run it for a full tank and pretty much peaked on the ground, then replace last season's glowplug with a new one, and throw the old one into the trash bin. The idea being to clean out the storage oil without corrupting a new glowplug. If the old one won't work at all, I'd look for a used one that at least glows brightly to get it going...then throw it in the trash bin. Flying sessions are too short/seldom already.   H^^ Steve
« Reply #24 on: February 25, 2014, 07:46:43 AM »
Thanks for the advice Steve,
Sounds pretty good to me. Unfortunately my pal has gone electric and seems there is no way back for him! So another one lost to LiPos. No chance with me, I have enough real engines to last the rest of my life! No way is the march of electric powered planes going to claim me as a victim. I like oily, smelly planes!
Andrew.
BMFA Number 64862
« Reply #25 on: February 25, 2014, 07:59:53 AM »
Andrew.
Just think of it this way: electric or IC you still get out and fly together!
I still think it weird having 4 engines needing a cleaning like that at the same time...had to be something with the storage routine.
Phil
« Reply #26 on: March 04, 2014, 12:34:11 PM »
This made me think of a friend of mine.  He is an outstanding pilot and always gets very good engine runs.  Near the end of a flying season, his #1 model started to experience engine run gremlins.  Not consistent!  After all the *usual* changes, a strange phenomenon showed up.  He always runs muffler pressure and the pressure nipple on the muffler was clogged almost solid.  He reamed it open and the great engine runs returned!  I would have probably never thought of that...........
BIG Bear
RNMM/AMM
