P T G suggested to me use some 3/16"x3/8" 6061-T6 alum that can be bolted to the fuse, then drill and tap the alum for the engine size that you want to try, if that engine doesn't work make another set of alum mounts, that will bolt into the original mounts, drill and tap mounts and install new engine...
Hope that this helps..........
