Although I tend to stay away from the larger 4S engines - I will use .40 max - I have done quite a bit of three way comparison between ENYA, OS and SAITO.
From a raw power standpoint, the ENYAs are just plain unbelievable. I've done a lot of flying with the .46 and .53 and they just don't let up. The .53, which I compared to the Surpass .52 and SAITO .56, pulled the 80 ounce Polaris as if it wasn't there. I would say that it's more powerful than any 2 stroke .60 I've ever seen, including piped setups.
The .46 is pretty close in power to an ST .60. It showed more pulling power than the Surpass .48 and SAITO .50.
Also of note - the ENYAs have two cams that can easily be re-timed for reverse running.
The Surpass line is a bit mellower but still delivers quite a punch. The Surpass .40 is the most powerful .40 I've ever seen - 2 or 4 stroke. I have flown the Surpass .26, .40, .48, .52 and .70. All do the intended jobs quite well. The only Surpass that a number of C/L flyers seem disappointed with is the .30. I have not used it so I cannot comment.
People have successfully replaced piped .60s with the Surpass .52 and claimed better performance and economy.
The SAITOs seem to be the most user friendly and popular for C/L flying.
I've used the .30, .40, .40A, .45, .50, .56, .72 and .91.
I will note that, as of late, I've witnessed some mechanical failures that have me a bit concerned.
To the subject at hand - the Surpass .56 will, I'm sure, find its way into a C/L bird. I'll be anxious to see how it performs.
