  • June 22, 2025, 07:58:12 AM
Author Topic: Magnum .36 burp in transitions.  (Read 1952 times)
Offline Stan Tyler
« on: July 30, 2007, 11:11:38 AM »
With a Magnum .36 on a profile, I've been getting a burp in the transitions from insides to outsides. Symptoms are similar to what a Fox .35 does.
Running an APC 10.5-4.5 prop at about 10,500 launch RPM on 10% nitro, 22% lube fuel. Consistent run with no run away, just a noticable burp in the inside to outside transitions or on a hard outside corner like in the outside square or the inverted turn in the wingover.
Any Suggestions?
Stan
Stan Tyler
AMA 3239
Offline dennis lipsett
Re: Magnum .36 burp in transitions.
« Reply #1 on: July 30, 2007, 01:12:28 PM »
Burp it after filling and before you fly. That motor  has gas.  #^  y1
Im sorry!!! the devil made me do it  LL~   LL~   LL~  mw~  mw~
Dennis
Offline Busby
  • ACE
« Reply #2 on: July 30, 2007, 03:23:47 PM »
Generally,with my Aerotigers or PAs it is doing its best to tell me to install a new plug.
Try an idle bar thundertiger.
Marshall Busby
« Reply #3 on: July 30, 2007, 03:55:31 PM »
Any Suggestions?
Stan
HI Stan
Can you tell  u s what type of  fuel you are using?  all castor? syn.?
What type of  glo plugs are you using?   is the motor  very lean or  rich?
Offline Stan Tyler
« Reply #4 on: July 30, 2007, 04:39:46 PM »
Hi Randy,
The plug I'm using is a new ThunderBolt R/C long. Fuel is a pretty generic stunt mix, 10% nitro, 11% castor/11% synthetic. The gallon can was opened about 2 months ago, and down to almost empty, could be a factor but same fuel runs fine in other motors on same day. I will try new fuel next weekend.
Motor is running with a tongue muffler, could be causing too much back pressure. The motor does not appear to be running too lean or too rich.
Forgot to mention, air temp was mid to high 80s.
Stan
Stan Tyler
AMA 3239
« Reply #5 on: July 30, 2007, 06:54:10 PM »
I have had a brand new plug be a "bad" one out of the bag.  Marshall (Busby) and Randy (Smith) were both there.  Put in another "new" one and it's still in the engine.
« Reply #6 on: August 19, 2007, 08:20:03 PM »
All else failing, I'd certainly try rotating the spraybar in about 10 degree increments from wherever it is now. It might help...or might not. Be sure to post your results.  H^^ Steve
Offline Dick Fowler
« Reply #7 on: August 20, 2007, 05:31:12 AM »
Below is  Lou Crane's reply to the thread - What is the "Fox burp"?  and explains why the "burp"  happens even on engines that don't suffer from an oversized case bypass channel as is the current theory for the Fox  burping. Makes sense.
Re: What is the "Fox burp"?
« Reply #6 on: August 19, 2007, 05:45:49 PM » Quote
Perry,
You could try searching (that input box at the top right next to the magnifying glass..) under wig-wag  for a post I put in a while back. Helps reduce 'burp' and getting in a first flight w/o starving or richening off the engine.
The reason for the burp may be related to the change of g-loading when the model kicks over from inside g to outside g at the intersection in the figure eights. Why it takes the form of an audible misfire or non-fire for some Fox 35s could be a very complicated combination of many things. If the tank, prop, plug and fuel are all good, and the setting is about right, you may hear a one or two step stutter without losing noticeable power, and without the engine shutting off.
The low round loops in the round Eights require about 10 to 11g for their shape, and the effect of gravity adds 1g at the bottoms and about 3/4 g at the top (trigonometry - at the angle that gravity works on the model at 45° line elevation.) The intersections are supposed to be vertical, so lift and gravity are at right angles - they don't interact at that split second... So the loads on the fuel are from 10-11g toward the wheels (in the inside) to the same range away from the  wheels (in the outside) and that's suppossed to happen in a hundredth of a second or less. Quite a change.
Dick Fowler AMA 144077
Kent, OH
steven yampolsky
« Reply #8 on: August 21, 2007, 09:09:04 AM »
Any Suggestions?
Try less oil, it may be cooling the head too much, especially considering that this is a profile. 18% all synthetic will work just fine.
Dave Adamisin
« Reply #9 on: August 21, 2007, 09:17:05 AM »
Stan, are you running muffler pressure? Transition burps can be fixed sometimes by opening the venturi up or lowering the fuel system pressure. If you are running MP, try adding a couple holes in the tongue or opening the venturi about .010".
Offline Stan Tyler
« Reply #10 on: August 21, 2007, 02:39:33 PM »
For the time being, I've swapped motors from the Magnum .36 to a Len Neuman modified FP35. Using the same fuel the FP35 doesn't have the burp that the Magnum did.
When time permits, I'll try the Magnum with less oil to see if it's over cooling. I typically don't run muffler pressure, but I did try both the tongue muffler and a Scott Dinger tube muffler, no difference between the mufflers, so I can probably rule out a backpressure issue.
Thanks for all the suggestions, when I have the chance, I'll try less lube in the fuel, a different tank (currently an older GRW hard tank), rotating the spray bar a little, and try another plug, although not all at the same time.
Stan Tyler
AMA 3239
Offline Bradley Walker
    • The Urban Rifleman
« Reply #11 on: August 28, 2007, 01:54:08 PM »
If I have to guess, I would say it was two words:
BOOST PORT
#1 reason for all misfiring, burping, going cold, etc...
Block the boost port in your Magnum.  I have one all done and ready to go.
-George Bernard Shaw
Offline Bob Kruger
« Reply #12 on: August 29, 2007, 08:19:46 AM »
BOOST PORT
Brad;
Have you flown it yet?  If so, I would be interested in your setup (prop, venturi, fuel, etc).
V/r
Bob
Bob Kruger
AMA 42014
