  • June 17, 2025, 05:58:30 AM
Author Topic: Enya needle and OS nva  (Read 1335 times)
Offline James Holford
« on: October 27, 2018, 06:53:10 AM »
Would a needle for an Enya .35 work on a NVA for OS .46LA?
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re: Enya needle and OS nva
« Reply #1 on: October 27, 2018, 12:08:20 PM »
NO  not unless  you drill the case out to install the larger diameter  Enya spray bar,  then you will need to  open up the  Venturi .025 to .030  to make the  size the same
Offline Dane Martin
  • heli pilot BHOR
« Reply #2 on: October 27, 2018, 05:42:02 PM »
Jamie, you mean does just the needle thread into the valve body?  If so, then negative. The valve body threads are smaller on the OS.
« Reply #3 on: October 27, 2018, 07:55:35 PM »
Yea thats what i meant. My dad needs a spring needle and I have a few new enya needles and was curious if it would work.
Jamie Holford
Lafayette, La
AMA #1126767
Offline Dane Martin
  • heli pilot BHOR
« Reply #4 on: October 27, 2018, 08:25:20 PM »
Oh, I broke an os needle valve body, but I have the needle. I'll send it to you
« Reply #5 on: October 27, 2018, 08:27:59 PM »
Sweet!!!!
Jamie Holford
Lafayette, La
AMA #1126767
