Steve, I guess it's mostly a matter of preferences...
Both approaches move the heavy bits of the engine rearward some, and allow a more streamlined front end. We pretty much have as much access to the same European long-nose engines as fliers there have, so that part of it should be moot. A shaft extension on a plain bearing engine remains not the best way to lengthen the front end...
Also, nitro is still quite expensive everywhere, and worse in Europe than here. Many Western, and now Eastern, European engines are - or were - set up to run "FAI Fuel" (80% methanol, 20% Castor). Even though F2B CLPA is not a specified-fuel event like Speed or Racing, the cost of nitro and availability of low/no nitro engines may be a factor.
For rigidity of mounting, a six-bolt mount system seems theoretically better. Many FAI Racing engines have (had?) another pair of mount lug holes up around the front bearing area. For us, that might get in the way of playing with thrust offset...
There are no Appearance Points in F2B, but the models are usually very attractive and well finished. Impression on judges doesn't have to show up as formal points on a scoresheet. And a model that has seen "a lot of development" (read: wear and tear) isn't automatically at a scoring disadvantage in F2B. The flashes off a gleaming, well-finished model glinting in the sun as it flies can be impressive and contribute to a judge subconsciously favoring it...
Then there is the idea that many of the most famous European engines are limited production, pretty expensive, and usually a bit 'different' to live with. Replacement parts also may need to be considered: our better fliers usually pack in several hundreds of flights a year on a single model. Normal wear can more easily lead to need for replacing something. Higher-volume production and parts availability have advantages for many of us who aren't shooting at placing well at NATS or World's every time.
You raise an interesting thing to think about...
