  • July 08, 2025, 08:53:30 PM
Author Topic: aero tiger 36  (Read 3244 times)
Offline Bootlegger
aero tiger 36
« on: July 14, 2017, 01:31:17 PM »
 I have a R Smith aero tiger 36 that I want to bench run some more, and have in mind using an A P C 10.5x4.5 using 10% nitro and 22% all synthetic oil.
  Does any one have some other suggestions, and why?
   Thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: aero tiger 36
« Reply #1 on: July 14, 2017, 07:18:47 PM »
     Run it until it snaps back to 4 smartly when you pinch and release the fuel line, then, go fly it. It's the best 4-2 break engine ever made in that size, and the best engine you can have that doesn't require a pipe.
Re: aero tiger 36
« Reply #2 on: July 14, 2017, 07:57:56 PM »
   Thanks a lot...
Is this the one I emailed you about?  number  155,  how many runs on it now?  is the rod still stuck at the top?  how long has it set un-run, after run oil in it?  It uses  20 to 22 % oil max  nitro doesn't matter
a 10.44 x 4.5  will be  OK   ,  11 x 4  will too
what is the shape the engine is in ? has it been  rebuilt?
If you need a  Aero Tiger instruction sheet I can email  one  to you
Re: aero tiger 36
« Reply #3 on: July 14, 2017, 08:01:17 PM »
The tuned pipe motors like a little more synthetic and I recommend a 15% synthetic, 7% castor blend or a  20% half and half with 1  ounce of Aero-1 fuel supplement. Although many use 1\2 – 1\2  with great success.  This works very well in the  Precision Aero , OPS and Max VF engines,  Super Tigre  Thunder Tiger, AERO TIGER and most all of these type engines..
For ABC, AAC ,ABL, ABC-R and ABN motors, start out in a very fast four-cycle and about every 45 seconds; pinch the fuel tube to kick the motor into a momentary two-cycle. These  types of engines  normally  take  more  break-in time than do their iron lapped piston cousins . If you can run the motor in a fast four-cycle and without touching the needle, pinch the tubing to lean the motor into a two-cycle for 20 seconds or so, then it should go right back to a four.  After breaking  in  the engine with a few  tanks of fuel , you can start using the needle  to cycle back and forth from 2 to 4 cycle. When it is broke in you should be able  to hold a 2 cycle for 30 seconds or  so,  and come back to a  4 quickly by turning the needle richer . If not, it probably needs more running time.
Re: aero tiger 36
« Reply #4 on: July 14, 2017, 08:54:02 PM »
  Hi Randy;
    I have a couple of Aero Tiger's tucked away for a rainy day. The next time you are sending things out, would you please email me the instruction sheet? I would like to have it saved on a computer and a thumb drive just for future reference. I hope to build something for them soon, just trying to figger out what I want.
  Thanks alot,
 dpmcenthusiast@aol.com
Offline Bootlegger
Re: aero tiger 36
« Reply #5 on: July 15, 2017, 09:03:41 AM »
  Yes Randy, This is the one that we conversed via email, and the wrist pin came loose or I would not have run it, I had it well oiled with marvel air tool oil, and it was loose when I took the back plate off yesterday, so I ran it once with a 10x4 prop.
  Thanks for all the advice and help..
Gil Causey
AMA# 6964
Offline Bootlegger
Re: aero tiger 36
« Reply #6 on: July 15, 2017, 09:05:37 AM »
 To Dan, and Brett I want to thank you for your help/advice also.. y1
Gil Causey
AMA# 6964
Re: aero tiger 36
« Reply #7 on: July 16, 2017, 07:46:27 PM »
Another Twin .  S?P
« Last Edit: July 16, 2017, 08:12:11 PM by Matt Spencer »
