  • July 11, 2025, 09:53:26 AM
Author Topic: Early Brodak 40  (Read 1592 times)
Offline Paul Allen
Early Brodak 40
« on: November 04, 2009, 03:12:35 AM »
Guy's
       Does any one know if the first run of Brodak 40's had a different
looking muffler to the last version?
Paul Allen
Offline Jim Oliver
Re: Early Brodak 40
« Reply #1 on: November 04, 2009, 05:13:32 AM »
According to the 'experts", the first run of B40s had a muffler with smaller diameter outlet than the later B40s.
Otherwise, the mufflers were/are the same.  My four B40s all have the same (later model) muffler.......
Cheers,
Jim
Jim Oliver
AMA 18475
Alan Hahn
Re: Early Brodak 40
« Reply #2 on: November 04, 2009, 07:51:20 AM »
I agree with Jim. I have two B40's, one from the second run and one bought at some later date. I looked at both mufflers last night, and as far as I can tell, the output opening looks the same.
I also have a B25, and there the output is considerably smaller, even though the mounting is the same. I wonder if the B25 muffler is basically the same as the first run B40.
Offline Jim Oliver
Re: Early Brodak 40
« Reply #3 on: November 04, 2009, 02:16:21 PM »
FYI,
http://www.brodak.com/shop_productdetail.php?ProductID=6281
Not exactly sure what this might mean..........
Jim
Jim Oliver
AMA 18475
Willis Swindell
Re: Early Brodak 40
« Reply #4 on: November 04, 2009, 04:28:59 PM »
I think this is a picture of the first of the first Brodak 40’s.
Willis
Offline Paul Allen
Re: Early Brodak 40
« Reply #5 on: November 05, 2009, 01:54:29 AM »
Willis
      Thanks, that looks like the picture I have.
Alan Hahn
Re: Early Brodak 40
« Reply #6 on: November 05, 2009, 07:47:26 AM »
FYI,
Jim
That is a little odd---I did pull out my 3 engines---"2nd" run B40, "newer" B40, and B25 (not first run, but purchased a few years ago), and the B25 muffler, while basically identical to the two B40 mufflers, has a much smaller diameter output opening than the B40 muffler. Maybe they decided the larger opening works better even with the B25???
Alan Hahn
Re: Early Brodak 40
« Reply #7 on: November 05, 2009, 06:23:18 PM »
Here's a photo of my B40 and B25 mufflers.
Offline Paul Allen
Re: Early Brodak 40
« Reply #8 on: November 05, 2009, 08:29:47 PM »
Guy's
        Here should be a picture of the muffler I'm talking about,maybe its not
the same as the one Willis posted.
Alan, you get your hands oily as well!
Paul Allen
Australia
Offline Greg Howie
Re: Early Brodak 40
« Reply #9 on: November 06, 2009, 02:11:56 AM »
I like the one with the pressure tap . Mine dosent have one , want to trade ?
Oh ....I see ,you mean the ones on a string ?
Greg Howie
Offline Jim Oliver
Re: Early Brodak 40
« Reply #10 on: November 06, 2009, 04:17:36 AM »
Paul,
From your pix, it appears that your muffler doesn't match the one shown on the instruction sheet............???
Jim
Jim Oliver
AMA 18475
Alan Hahn
Re: Early Brodak 40
« Reply #11 on: November 06, 2009, 08:35:30 AM »
Paul,
Yours certainly looks different in shape than mine---both of which are shaped like the one Willis showed.
Offline Paul Allen
Re: Early Brodak 40
« Reply #12 on: November 06, 2009, 02:12:22 PM »
I have a Brodak 40 that I purchased back in July,2003 going by the receipt ,and
the muffler is the same as the one on the instruction sheet,it had a bigger outlet
hole and was from the second batch that was made.
The 40 in the photo, I just purchased from E bay in Australia,NIB.
I just wondered if this was the muffler from the first batch?
When was the first Brodak made?
Paul Allen
