  • June 19, 2025, 04:02:16 PM
Author Topic: ID Engine  (Read 1669 times)
Offline t michael jennings
  • AMA 83322
ID Engine
« on: November 08, 2016, 04:03:32 PM »
Gentlemen,
A friend gave me a basket case engine.
Dirty, piston froze, all the parts were there and he said it was an old Fox 35.
Worked a couple of hours on the engine and it is shaping up.
Although, not sure if it is an Fox 35.  Info about the engine:
   1.  Cylinder bore:  0.800 inch
   2.  Stroke:            0.677 inch
   3.  Head has 4 bolts,
   4.  Back plate has 3 bolts,
   5.  Engine has no markings.
Thanks for the help in Identifying this engine.
T Michael Jennings
Knoxville, TN.
Re: ID Engine
« Reply #1 on: November 08, 2016, 05:22:51 PM »
  I think that is an early version of the three bolt back plate but still had four bolt head. I don't think it's a sand cast engine. If you go over to Stuka Stunt and do a search, I think someone posted pictures one time of the complete line of Fox .35s from the beginning to that point.
  • AMA 83322
Re: ID Engine
« Reply #2 on: November 08, 2016, 06:57:29 PM »
Dan,
Thanks, your advice where to look was right on.
This engine is a 1951 FOX Stunt 35.
T Michael Jennings
Knoxville, TN.
Offline Mike Bufkin
Re: ID Engine
« Reply #3 on: November 09, 2016, 04:41:41 AM »
Yep,
Sandcast Fox 35.
You've got a good one,I just saw one go on Ebay for $ 69.00
All sandcast's have that little divot on the front bypass side mounting lug.
Offline Mike Bufkin
Re: ID Engine
« Reply #4 on: November 09, 2016, 04:47:11 AM »
