  • June 19, 2025, 11:34:03 AM
Author Topic: S/T 46 aand oil.  (Read 1310 times)
Offline bob whitney
S/T 46 aand oil.
« on: November 06, 2016, 04:30:22 PM »
  a few years back at VSC I was running a s/t 46 on a jamason with 22% oil Powermaster  10% nitro / I could not get a steady run, a wise old man ,Bill Haywood gave me some 10%fule with 28% oil and the Tigre ran great all weekend .
 this weekend a friend of mine was running a S/T 46 on 22/10 and could not hold a setting for 6 test flights   today I added some caster to his fuel and he had 2 perfect runs without ever touching the needle
rad racer
Re: S/T 46 aand oil.
« Reply #1 on: November 08, 2016, 08:00:11 AM »
Sounds like the piston ring ain't right. Mine runs great on 10% with 50/50 oil. They say that engine will coke up if you use all castor for long.
