  • July 13, 2025, 06:32:39 PM
Author Topic: Double Star .61 Light  (Read 3728 times)
John Leidle
« on: August 20, 2013, 08:09:18 AM »
  Can you guys tell me your experiences W/the Double Star engine? I am interested in one after the success I've had W/the .54 .  I know they are out of production but they might be coming back. Maybe you have witnessed otherguys using them.                 John
Offline Steve Fitton
Re: Double Star .61 Light
« Reply #1 on: August 20, 2013, 02:11:27 PM »
Which one? The side exhaust DS 60 lite or the rear exhaust DS 61?
John Leidle
« Reply #2 on: August 20, 2013, 08:08:47 PM »
  The Rear Exhaust ..
« Reply #3 on: August 21, 2013, 06:24:30 PM »
I have extensive experience with the side exhaust but not the rear exhaust.  Not too many of the 61REs were made and those that I saw in service gave their owners the devil of a time with the run.  Tom's original 61RE in his Avanti used 7 to 8 inches of pitch and seemed to work ok, as did Andy Patterson's Avanti setup.  The rest that I saw were not very good.  The chief issue was that the engine would not burn more than 4 to 4.5 oz fuel and made about the same power as a Fox 35.
« Reply #4 on: August 21, 2013, 09:00:18 PM »
Total Junk
« Last Edit: October 10, 2013, 06:08:59 PM by Ed Ruane »
steven yampolsky
« Reply #5 on: August 22, 2013, 06:28:55 AM »
Norm Liversidge uses his with great success. I have not seen that motor give him a bad run ONCE! Set it up as per Tom Dixon and you'll never have a problem
John Leidle
« Reply #6 on: August 22, 2013, 12:07:49 PM »
   Thanks everyone,  I'm looking for a rear exhaust big bore engine. The Double Star looks inviting.
Offline Balsa Butcher
  • High Desert Flier
« Reply #7 on: August 22, 2013, 03:22:02 PM »
Ever considered a Ro-Jett? 51's, 61's, and 67's are RE and work great on pipe or RE muffler. Currently in production and supported. Joe Gilbert won the recent Albuquerque contest with a .67 on a pipe...high DA, gusty winds, lots of power, impressive. PA's too, if you can find someone willing to sell - I know I won't sell the one I have. ;D
Pete Cunha
Sacramento CA.
AMA 57499
  • High Desert Flier
« Reply #8 on: August 22, 2013, 04:02:35 PM »
Another alternative that is currently available is the Stalker 61 RE. 8)
Pete Cunha
Sacramento CA.
AMA 57499
John Leidle
« Reply #9 on: August 23, 2013, 06:25:13 AM »
  I could be somewhat interested in the ROjett  .67 or big block .But I am never sure of the status & wheather or how they are going to be I read so many different things here & there about them.
  • High Desert Flier
« Reply #10 on: August 23, 2013, 08:48:47 PM »
I can answer a few of your questions: The .67 is currently in production and is the most popular Ro-Jett C/L engine. Order directly from Dub Jett, lead time is usually only a few weeks and he is very easy to work with. Dub also offers excellent support after sale. I don't wish to compare them to PA's which are also excellent engines. I like the .67 over the .76 as it has the same mounting holes as the RO-Jett 60 and 65...and PA's and VF 40/46's. 8)
Pete Cunha
Sacramento CA.
AMA 57499
John Leidle
« Reply #11 on: August 24, 2013, 08:12:43 AM »
  Thank you for your time ,,, I couldn't find the weight of the RO-jett .67 &  .76.
  • High Desert Flier
« Reply #12 on: August 24, 2013, 06:47:24 PM »
RO-Jett .67: 13.1 ounces without header. Don't know about the .76.  8)
Pete Cunha
Sacramento CA.
AMA 57499
John Leidle
« Reply #13 on: August 26, 2013, 11:07:58 AM »
  Thank you.
Offline Jim Morris
« Reply #14 on: August 26, 2013, 12:51:31 PM »
I ran the DS RE in my modified Time machine for a while, yes a 7 1/4 pitch prop,sounded like a tractor LOL, but it later got to where it wasnt running consistantly no matter what I tried, pulled it and put in a Stalker 55RE, ran like a top.
John Leidle
« Reply #15 on: August 26, 2013, 10:05:10 PM »
  I have a Double Star .54 that started an odd way of running a while back, For no reason it would run richer as the flight progressed. I tried all my tricks & it didn't help.  One fine day it ran properly & it has ever since. I have no idea.
