  • June 18, 2025, 07:36:13 AM
Author Topic: fuel for PA75  (Read 882 times)
Offline bob whitney
fuel for PA75
« on: December 17, 2019, 12:33:14 PM »
what is a good fuel mix for the PA75
rad racer
Re: fuel for PA75
« Reply #1 on: December 17, 2019, 01:47:55 PM »
  Powermaster RC "Air" (18% 50/50 oil), or Powermaster RC "Air" with David's mix of added synthetic and castor to get it to 22%. I think David usually runs 10% nitro at sea level, and 12.5% at Muncie.
   SIG is not recommend due to the "tater" issue.
Re: fuel for PA75
« Reply #2 on: December 17, 2019, 03:09:25 PM »
whatever  fuel  you buy or make use    20 % oil  with mostly synthetic, I would not use over  1/4 of it being castor . Many make their fuel and  use  Super Techniplate, which is 25% castor, Use  5% in cooler months, and ... IF... is needed.  then go to 7.5%  , 10%, Sig is  oK  but NOT  SIG Champion, as it has  way too much castor in it, and  as Brett  said  will tater up badly,  I have used a lot SIG 4 Stroke fuel, with 2 ounces castor added
Offline bob whitney
Re: fuel for PA75
« Reply #3 on: December 17, 2019, 05:36:32 PM »
thanks guys ,RAD
rad racer
