Engine basics => Engine set up tips => Topic started by: bob whitney on December 17, 2019, 12:33:14 PM
what is a good fuel mix for the PA75
Powermaster RC "Air" (18% 50/50 oil), or Powermaster RC "Air" with David's mix of added synthetic and castor to get it to 22%. I think David usually runs 10% nitro at sea level, and 12.5% at Muncie.
SIG is not recommend due to the "tater" issue.
whatever fuel you buy or make use 20 % oil with mostly synthetic, I would not use over 1/4 of it being castor . Many make their fuel and use Super Techniplate, which is 25% castor, Use 5% in cooler months, and ... IF... is needed. then go to 7.5% , 10%, Sig is oK but NOT SIG Champion, as it has way too much castor in it, and as Brett said will tater up badly, I have used a lot SIG 4 Stroke fuel, with 2 ounces castor added
thanks guys ,RAD
