  • June 18, 2025, 06:14:57 AM
Author Topic: CYCLONE PROPS ....Where from ?  (Read 1012 times)
Offline Robin_Holden
« on: September 22, 2008, 01:27:30 AM »
Hi guys from the French countryside .
Where do I buy CYCLONE props please ?
I've e-mailed Thunder tiger 4U twice .....No response ..... Great !
Also , are they any good for stunt please ?
Much obliged ,
Robin, [ Ex-pat Brit in the Charente FULL of ex-pat Brits ! ]
Re: CYCLONE PROPS ....Where from ?
« Reply #1 on: September 22, 2008, 10:47:07 PM »
Much obliged ,
Hi Robin
I stock the  Cyclon  props, you can reach me  at   Randyaero@msn.com
Offline don Burke
« Reply #2 on: September 23, 2008, 03:45:05 PM »
I haven't e-mailed thudertiger4u but I sure have used their web site and ordered things on-line, including cyclone props.  Never a problem and quick responses.
don Burke AMA 843
Menifee, CA
« Reply #3 on: September 23, 2008, 06:59:39 PM »
I can tell you that the 11x4.5 Cyclone works very well on Brodak .40's, Magnum .36's, and I've seen Randy Powell using it on his .40VF/tuna pipe. I would also expect that size to work well on .40LA's and maybe .35/.40FP's. Very nice props, well balanced, pleasent appearance (I've not figured out why guys complain about the looks of a prop that works, when it's running 10,000 rpm), and relatively easy to fit into a spinner. I'm not sure how tough they are, as I've not broken one or seen one broken. But I did buy a dozen of the 11x4.5's, plus a few other sizes that are stunt appropriate.  ;D Steve
Offline dennis lipsett
« Reply #4 on: September 28, 2008, 01:10:39 AM »
These are in my opinion the best prop for the money . They may not be the ultimate for a top notch contest ship but I've used too many of them to say that I've ever been disappointed with them. Did I mention that they are CHEAP to buy, balance is generally right on , my engines seem to be quieter with them? and they are just heavy enough to provide some flywheel effect to most engines. I've never tried to twist them and doubt that it can be sone, don't hold me to that though. they will break and reasonably easily on asphalt.
Dennis
