  • June 14, 2025, 09:40:53 PM
Author Topic: Inboard gas tank.  (Read 981 times)
Inboard gas tank.
« on: September 24, 2008, 09:09:08 PM »
like a R/C thing , profile,
Tank inboard and level with engine.
Any problems with this set up ?
Re: Inboard gas tank.
« Reply #1 on: September 24, 2008, 10:15:17 PM »
only thing i can think of might be a tendancy to richen as flight speed comes up due to increased head pressure felt at the needle
Offline Ralph Wenzel (d)
« Reply #2 on: September 25, 2008, 07:28:28 AM »
It can work very well. You can set the engine for max power for takeoff, and then it'll richen up a bit for level flight, leaving you with some reserve for maneuvers. It should not be set up with "ram air". That can lead to too much richening in level flight. If you're using a uniflow tank, be sure the uniflow is in some neutral area, like near the backplate of the engine.
Ralph
Ralph Wenzel
AMA 495785 League City, TX
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: September 25, 2008, 05:42:25 PM »
I have 3 profiles with inboard tanks.. All clunks on muffler preasure.. Works great...
« Reply #4 on: September 27, 2008, 10:51:44 PM »
Thanks. its got something to do with a Hawker Typhoon.
