  • June 22, 2025, 06:46:04 PM
Author Topic: CS 36P engine  (Read 1098 times)
Offline rich gorrill
CS 36P engine
« on: September 16, 2013, 04:55:45 AM »
Hi guys, crusin E-Bay and came across a sale on a CS 36P engine. Has anyone ever heard of these engines. It is brand new and looks pretty good. The box shows it is made in Japan. It is a control line motor with needle valve and venture. It also comes with a strange looking muffler, very long. Any info would be appreciated. I don't think I'll bid on it I am just curious if anyone has ever used this engine.
TIA,  Rich
Offline richardhfcl
  • AMA 82448
Re: CS 36P engine
« Reply #1 on: September 16, 2013, 06:18:33 AM »
Rich,
     I had thought that CS engines were manufactured in China and that the first series of .049's
marketed by Brodak were made by CS.  I have no knowledge of their QC, however.  Let us know
how the engine works out for you should you purchase it.
Richard Ferrell
AMA 82448
Offline BillLee
Re: CS 36P engine
« Reply #2 on: September 16, 2013, 08:22:58 AM »
TIA,  Rich
Perhaps you're looking at a different CS 36P engine on eBay than I am, but both the box and the casting of the engine backplate clearly says "Made in China". Looks like another OS clone.
Bill Lee
AMA 20018
Re: CS 36P engine
« Reply #3 on: September 16, 2013, 08:31:48 AM »
You are right, it does say made in China. Does anyone know if this was the only engine made in China?
Offline 55chevr
Re: CS 36P engine
« Reply #4 on: September 16, 2013, 12:57:51 PM »
That is a rough casting ... It looks like an OS FP knock off with more fins added.
Joe Daly
Offline Andrew Tinsley
Re: CS 36P engine
« Reply #5 on: September 16, 2013, 01:35:37 PM »
Gentlemen,
CS has often been interpreted as Chinese S--t and to be frank the usual quality is such as to regard the engine as a kit of parts that need fixing. They do make the occasional good engine. I have an ED Hunter replica and that is excellent, however that doesn't often happen. Unless you are a good machinist, leave well alone, you can do without the hassle.
Andrew.
BMFA Number 64862
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
Re: CS 36P engine
« Reply #6 on: September 18, 2013, 07:36:49 PM »
Leave that one, what you need is an OS 35. There are still a few of these around as they crop up on ebay now and again, if you can find a good one.
Good luck,
Tim
