  • July 12, 2025, 10:08:17 PM
Author Topic: Crankcase pressure  (Read 1879 times)
Offline Andrew Tinsley
Crankcase pressure
« on: May 11, 2013, 07:29:40 AM »
I have been following the theme about muffler pressure for stunt. My query is what about crankcase pressure for some of the more potent 1/2A engines? I have been experimenting with an MP Jet engine which goes like a bomb when you find the correct diameter of crankcase nipple. It all seems a bit hit and miss to me. So is there any rule of thumb for this type of pressure feed?
I took me a little while to figure out why there is an average positive pressure in the crankcase, but I still feel a one way valve would be an advantage. I know this isn't normal stunt application, but those people that have it mastered, do some very impressive stunt schedules!
Andrew.
BMFA Number 64862
Offline Jim Thomerson
Re: Crankcase pressure
« Reply #1 on: May 11, 2013, 10:59:54 AM »
I have used crankcase pressure pretty constantly with TD 049, 09 and 15.  I used a one way valve.  I tried it without the one way valve and got an occasional inconsistent result.  I tried crankcase pressure on a Fox 35 and destroyed the piston and liner with lean runs.  I could not set it rich enough on the ground to stop it going really lean in the air.  S?P
« Reply #2 on: May 11, 2013, 11:16:08 AM »
Thanks Jim,
 had a suspicion that a one way valve would be a good bet. Are there any valves that you could recommend. The ones I have are a bit on the large side for 1/2A. I wonder if the hit and miss results I got are due to the fact that I omitted the one way valve. I tried the scientific approach and started with a very small aperture and just kept on increasing the diameter. The results were very inconsistent and I couldn't really tell what was happening!
Thanks Andrew.
P.S. The AM25 is doing sterling work and is now powering grandson's first "big" (!) stunt job.
BMFA Number 64862
Offline rustler
« Reply #3 on: May 11, 2013, 01:17:56 PM »
I guess a shaft timed pressure take-off is a one way valve?
Ian Russell.
Offline BillLee
« Reply #4 on: May 11, 2013, 04:33:14 PM »
Back in 1978, I wrote in my CL Racing column in Model Aviation:
A good question to ask here is, "How much does
this pressure change affect the total pressure in at
pressure system?" In order to find an answer to this,
you have to know the pressure that is created in the
tank by using crankcase pressure. I set up
a test stand to measure this and found that the tank
pressure from an untimed crankcase tap is about 1.4
psi, or about 1.6 psi if a ball-check is used in the
pressure line.
The entire column can be seen at http://www.nclra.org/TechTopics/UniflowPhysics.pdf
« Last Edit: May 12, 2013, 02:15:42 AM by BillLee »
Bill Lee
AMA 20018
« Reply #5 on: May 11, 2013, 04:44:24 PM »
I have small, well guarded,  stash of KK one way valves.  KK made a pressure backplate for the TD 049 which had a built in one way valve.  I think someone told me Jett engineering made a small diameter one way valve. I'd also look at Texas Timers website to see if they have anything.
« Reply #6 on: May 11, 2013, 10:32:10 PM »
I believe these are what Paul and Howard used on the B-17 "909", very possibly modified.  H^^ Steve
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXG850&P=7
Online Howard Rush
« Reply #7 on: May 13, 2013, 12:07:43 AM »
Those are nice one-way valves.  We used them (actually just the shell with new innards) for an entirely different purpose.
Crankcase pressure allows a bigger intake, but doesn't work very well for stunt runs on the rich side of peak RPM with engines that have a negative slope of crankcase pressure with RPM.  The richer they get, the richer they get until they quit.
Offline L0U CRANE
« Reply #8 on: May 18, 2013, 02:06:52 AM »
To: Rustler -
Timed shaft pressure is quite a bit higher than 'averaged' case pressure, as it is only pumping when the piston is on the way down. The shaft intake port hole closes before the piston starts to rise significantly. A check-valve also prevents cyclical pressure drop in the case from affecting fuel delivery.
Years back, I made a few, flawed, attempts to measure the pressure from muffler, averaged-case and shaft-timed pressure operation. Scatter of observations with cheap Pep Boys type pressure guages negated anything conclusive.
The trend was there, however:-
Lowest: muffler pressure
middle-ground: averaged case pressure
highest: timed (shaft port) pressure.
Otherwise, only inflated bladder pressure tanks  - as in glow combat - exceed any of the above as a fuel delivery pressure source.
\BEST\LOU
Offline rustler
« Reply #9 on: May 18, 2013, 02:26:20 PM »
Hi Lou. Trust you are well. Missed you at VSC this year, - yes we got there!
I'd be interested to know results for "average c/case pressure with a one-way valve in the pressure line". I guess it should be similar to shaft timed?
I have somewhere a couple of n.i.b. (but rusty!) American tanks (K&B from memory?) apparently with one-way valves in them somewhere. Any advice or comments on these? I'm reluctant to use them, the're headed for da bay I think.
Ian Russell.
Offline Brian Hampton
« Reply #10 on: May 18, 2013, 07:44:54 PM »
Sometime way back in the 70's I did an experiment on an ST G20/15 to find out what untimed pressure was and from memory it was 1.5psi. The pressure guage was a simple water manometer where 1psi = 27.75". Although I've never checked it, I believe muffler pressure is around .1psi and a simple way to test it is to lower a length of fuel tube into a glass of water until it stops bubbling. Timed crankcase pressure is around 6psi so you'd need quite a tall manometer to measure that (or use mercury instead of water).
Offline BillLee
« Reply #11 on: May 18, 2013, 08:49:12 PM »
See reply #4
Bill Lee
AMA 20018
