  • June 22, 2025, 09:12:12 AM
Author Topic: Fox 40 C/L [Bushing] .....Tips Please !  (Read 923 times)
Offline Robin_Holden
« on: September 16, 2008, 01:32:36 AM »
Greetings [ again ! ] from S.W.France.
I bought a Fox 40 [ plain bearing ] ages ago and did my careful running - in procedure.
Any tips guys as to .....
Which prop suits ?
Fuel ?
Plug recommendations ?
Plus any other advice would be gratefully received.
As ever , much obliged.
Robin [ Ex-pat Brit in the Charente full of ex-pat Brits .... escaping Brown's Socialist ' Paradise ' ].
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Fox 40 C/L [Bushing] .....Tips Please !
« Reply #1 on: September 16, 2008, 03:40:55 PM »
Just treat it like a big Fox 35, lots of oil mostly castor.. Try searching for "GMA Fox 40" and see what comes up...
Offline Bill Heher
  • Fix-it
« Reply #2 on: September 17, 2008, 08:19:10 AM »
Check out this link - http://www.the.elmores.btinternet.co.uk/engine_tests/_cat001.html - it has orignal reviews for many of our classic engines, along with performance data/ fuel used / prop vs RPM charts. The Fox 40 is in there and it is worth the time to read the info.
Your 40 CL stunt is a big torque monster that should haul a fairly large plane, but will need a good size fuel load.
Bill Heher
If it's broke Fix-it
