  • June 19, 2025, 01:59:15 PM
Author Topic: Converting two 2 bladed props into one 4 bladed prop?  (Read 2192 times)
Offline frank mccune
« on: January 02, 2016, 07:28:23 AM »
       Hello All:
       Has anybody taken two 2 bladed props and converted them into one 4 bladed prop?  I was thinking that it would be a good idea for a scale project and a way to gain a bit of ground clearance to avoid having to use large diameter props.
       Perhaps a cross lap joint on each prop that is pinned and secured with a good adhesive would be adequate.  The joint could be made on a milling machine and the holes for the pins made on a drill press.  Once the machines and jigs were set up, many props could be rapidly fabricated.
       I think that with the talent available on this site, this could be possible. There are many facets of engineering to consider in this quest but it can be done.
        Thoughts and/or suggestions?
        Best for 16,
        Frank McCune
Online Lauri Malila
Re: Converting two 2 bladed props into one 4 bladed prop?
« Reply #1 on: January 02, 2016, 01:48:05 PM »
Frank,
I would join 4 (or even 5) blades in same way as I join 3 blades; simple butt joint, paying attention to correct gluing technique, secured with 2 carbon rings. All kinds of complicated finger joints are waste of time, me thinks.
Lauri
« Reply #2 on: January 02, 2016, 02:13:16 PM »
Something that adds strength both top and bottom, like Laurie's CF rings, please my mechanical intuition better than just taking a couple of props with honkin' big groves in them and gluing them together.
I suspect you could just use CF disks, sunk into appropriate rabbits, rather than a ring.  But I haven't fabricated any props myself, so I can't say.
« Reply #3 on: January 02, 2016, 04:15:32 PM »
       Hi Lauri:
       Your method looks very nice! I just threw out the idea of a cross lap joint to prime the pump.
       Back in the day, a company called Temco? used ring type of fasteners to join large built up beams together.  These rings were countersunk into the beam and secured by a through bolt.  I have not seen these things since the early 60's.  It looked like a good way to join laminated beams.  Your carbon ring reminded me of this type of joinery.
        Have a great 16,
        Frank
Online Lauri Malila
« Reply #4 on: January 02, 2016, 04:37:21 PM »
Frank,
I have used dural rings, steel rings, titanium rings and also filled the groove with epoxy-wetted carbon or kevlar rowing, all works well. It was sheer luck that I found the ready carbon rings, they are the nicest so far.
I copied this construction from Sandor Havran (HUN), he uses steel rings.
I also have a ST.60 prop somewhere given by a chinese sportsman, it has just one apr. 1/16" aluminium plate at centerline of the hub, and then 2 metal pins/blade to keep them in place.
My point is that often people over-engineer these things. L
« Reply #5 on: January 02, 2016, 09:22:05 PM »
If you ' cross lap ' them , leave a radius rather than a hard edge , in he bottom corners of the ' trough ' . a 32'd do . NOT a hard edge .
Offline Mike Greb
« Reply #6 on: January 03, 2016, 11:03:54 PM »
for a 4 blade prop you  could stack one prop on top of another.   I tried that bench running a ST90 and it seems to work.  Wonder what would happen if you used two different pitches and or diameters?   What angle would be the best?  traditional 90degrees, or how about 0 degrees, a biplane prop.  Or even have the second prop follow in the slipstream of the first prop?
