Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 06, 2025, 08:52:50 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
OS Max-H 40 wrist pin
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: OS Max-H 40 wrist pin (Read 1379 times)
Bill Johnson
25 supporter
Trade Count:
0
Captain
on:
December 28, 2015, 11:42:34 AM »
Are these wrist pins supposed to be full-floating?
I just got one completely apart. Had to extract the wrist pin with a screw threaded into it. The reason I ask if they are supposed to float is because of the Teflon pads on each side.
Logged
Best Regards,
AMA 350715
RandySmith
Administrator
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Re: OS Max-H 40 wrist pin
Reply #1 on:
December 28, 2015, 11:37:46 PM »
yes if they have teflon or delrin pads on the end, they are floating, even brass pads are in some OS engines
Logged
Bill Johnson
25 supporter
Trade Count:
0
Captain
Reply #2 on:
December 29, 2015, 06:53:05 AM »
Thanks, Randy. I thought so but just wanted to make sure.
Even after multiple trips through the crock pot and a couple dips in decarburizing solution, it still took a lot of force coming out and seemed consistent until it finally popped out.
Logged
Best Regards,
AMA 350715
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Jump to:
=> Engine set up tips
