  • June 03, 2024, 05:01:06 AM
Author Topic: convert os la40 r/c to C/L  (Read 1677 times)
Offline Ronald Hopping
  • if your not flyen your not tryen!
  • they all gotta die someday!!!!
« on: July 22, 2006, 07:45:22 PM »
Does anyone make a conversion to go from a r/c carb to a single needle carb?and whats a good source for aftermarket mufflers?Thanks Ron
Ronald
Offline Tom Perry
Re: convert os la40 r/c to C/L
« Reply #1 on: July 22, 2006, 08:28:13 PM »
My local hobby shop ordered my venturi, part #23312000.  This is for the OS .40 FP, but it will fit the OS .40 LA-S.
Ty,
Yes it will.  Ther are two O.S. venturi that will fit. 23312000, the one you have and 23312100 which has a smaller throat opening.  I use the second number as I prefer the O.S. NVA.  If I used an ST or ST clone needle valve I would consider the 23312000.
« Last Edit: July 23, 2006, 12:29:42 AM by tperry2054 »
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline Tom Dugan
« Reply #2 on: July 22, 2006, 08:28:21 PM »
You can order one directly from Tower Hobbies  http://www2.towerhobbies.com/cgi-bin/wti0005p?&I=OSMG1440&P=Z  you can also get the needle valve there to.  You might also want to get the venturi for the 20/25 so you have a different size in case you need it http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCW99&P=M .
Thomas
« Reply #3 on: July 23, 2006, 04:39:26 PM »
You don't need the small venturi to control a .40LA, so just get the bigger one. It'll be fine. You might want to try a Bruline air filter, tho. Get both fine and course filters.
I have no fondness for the OS needle valve assembly, having used them, ST's, ST Clones, K&B's and Nelson/Randy Aero, in recent history. I'd rate the Nelson/Randy NV setup to be #1 by a bunch.
Mufflers: The stock one works well if you can stand the weight. If not, a Randy Aero, Big Art or Scott Dinger tube muffler would work very well. The lightest and cheapest is the RSM Tongue Muffler, but I prefer a tube muffler for the quietude. You probably will also, and it may help your flying, leaving you more relaxed and able to concentrate better. Just $.02 worth.  y1 Steve
« Reply #4 on: July 24, 2006, 10:27:41 PM »
Nelson/randy aero,where can i laocate them and do you have a part#I agree i would like a tube muff.Ron
Ronald
Offline Leester
« Reply #5 on: July 25, 2006, 02:16:11 AM »
Ron: Nelson/Randy Aero is Randy Smith the moderator of the engine forum www.aeroproduct.net
Leester
ama 830538
