  • June 16, 2025, 02:59:19 AM
Author Topic: Como 51, good for stunt use?  (Read 1828 times)
Offline Manuel Cortes
« on: October 05, 2006, 05:42:25 AM »
Hello all.
Iīve the oportunity to obtain a good price Como 51 engine in very good condition.
I have check itīs a baffle ported engine and suspect can be a good stunt power plant.
Have someone experience with these engines in stunt use?
Thanks in advance.
Regards.
Offline peabody
Re: Como 51, good for stunt use?
« Reply #1 on: October 05, 2006, 05:58:58 AM »
The "word" that I got from all of the respected engine guys here is that they should be avoided...
Offline Tom Dugan
« Reply #2 on: October 05, 2006, 06:29:48 AM »
Manuel,
I have a couple Como engines and have heard about the same as Peabody.  It's primarily due to the weight, however, if a Como 51 is used for CL then it is better to use the baffled 51.
Thomas
« Reply #3 on: October 05, 2006, 10:20:11 AM »
Hello all.
Thanks in advance.
Regards.
Hi Manuel
I ran several of them years ago, They are  very good  stunt  engines. I used one in a  Magnum for several years. The baffle piston version is the good  one. The flat top  loop scavaged one  is  not.  Look inside the  exhaust port, if it has  a  baffle on the piston, it will run just  like a  ST-60. I ran a .179  true venturie and  a  ST 60  tube  muffler.
« Reply #4 on: October 06, 2006, 06:15:35 AM »
Thanks very much for your help.
So it seems is very powerful for a 51, what prop it would swing aprox??
Thanks again.
« Reply #5 on: October 06, 2006, 01:27:02 PM »
Thanks again.
Hi Manuel
I used  a  Bolly 12.5 x 5.5  2  blade   and  also  a  Bolly 12 x 6.5 n  3 blade  with  very good  results. very nice  4-2  , 10% nitro  22% oil.
The motor is about the same  weight as the  new G-51
« Reply #6 on: October 07, 2006, 02:59:51 AM »
Thanks Randy:
Is the venturi insert dimensions same as the new G51. In this case, si possible for you to supply me some true venturis for them?
