  • July 13, 2025, 06:12:13 AM
Author Topic: blank  (Read 2152 times)
blank
« on: September 10, 2018, 04:59:40 PM »
blank
« Last Edit: September 22, 2021, 08:11:15 AM by Motorman »
Re: Change LA40 to 46
« Reply #1 on: September 10, 2018, 05:43:02 PM »
   You should be able to measure what you got and figure that out.
« Reply #2 on: September 10, 2018, 07:30:09 PM »
It'd be easier to convert a LA 46 to a LA 40 .  ;D S?P
or just find a past it leaky .46 & refit it .
« Reply #3 on: September 10, 2018, 08:30:09 PM »
Why not just find a .46 case?
« Reply #4 on: September 11, 2018, 01:03:25 AM »
Motor,
According to OS, the cranks and the rods are the same for the 40 and 46 LAs. These actually came out of the 35/40 FP engines. I got this info from the OS website:
     https://www.osengines.com/parts/xr13390.html
That explains why the 46 vibrates more than the 40. Bigger, presumably heavier piston but same counterweight.... Might be time to lighten both the piston and the rod on my 46.
I don't know the answer to your head bolt pattern question.
PS--Ok, I was curious about this topic, so I lined up two OS-powered profiles and here's what I can see--the head bolt patterns are not the same. I didn't take apart either engine to get accurate dimensions. I just used a caliper to eyeball the centers of the screw heads. It is a trapezoidal pattern. The lateral spacing of the forward bolts looks the same. The lateral spacing of the aft bolts looks the same. The fore and aft spacing on the 46 is significantly bigger. I thought the head casting might be the same. The fore/aft dimension on the 46 was only about .015" larger. It does not answer the question you really want to know, which is how much meat is there between the case bore and the existing screws on the 40 case. You might end up cutting into the gasket/seal area, which by itself isn't impossible. You might also have to notch the flange on the 46 liner.
« Last Edit: September 11, 2018, 01:23:42 AM by Dave Hull »
« Reply #5 on: September 11, 2018, 09:04:24 AM »
Sorry - I forgot that some of us do things just to see if we can do it.  That sort of time is NEVER wasted even if it doesn't work!
Go for it - Ken
« Reply #6 on: September 11, 2018, 10:30:36 AM »
Motorman, I took a look at this awhile ago.  If you've got the equipment it is fairly straight forward.  The toughest part would be squaring up the block on a lathe and boring it smoothly and perpendicular to the crank.
Take another look at the bolt pattern.  I didn't measure it, but it looks the the 40 bolt spacing will require relieving the cylinder flange to fit the bolts.  Or just making an entirely new head to fit with repositioned bolt holes.
It'd be a lot easier to find a beat up 46RC and just replace the piston and liner.
« Reply #7 on: September 11, 2018, 04:40:57 PM »
Best option,  find a  cheap used  46 LA
These parts  are not the same
piston sleeve
wrist pin
head
head shim
case
these are the  same  : crank for  FP 35 40, LA 40 and LA 46 is  the same part, although there is one that has less counter weight
Backplate
B Plate gasket
Rod
washer  thrust
washer  driver
prop washer
prop nut
Needle Assembly
Venturi ( except for some 40 FP ones that are taller)
Remote  NVA  and  bar  will fit all if you want to use them
Mufflers will fit  all these   but  will  vary on size and back pressure  depending  on which one you  use
