  • June 17, 2025, 08:55:39 PM
Author Topic: Stress Cracking in Tin Tanks  (Read 2755 times)
« on: September 10, 2018, 11:38:18 AM »
I had an interesting flight at Chehalis yesterday -- the engine was really winding up, and it flamed out with an empty tank right after the triangles.  My launcher said he felt a "cold sprinkle" as I flew by on the first lap.
On inspection, the tank has a stress crack right where one of the tubes exits the tank.
It's pretty obvious that I over-stressed the metal.  That tube goes in fairly close to the top outside edge of the tank, and the way I installed it I tightened up the radius of the bend at that point, and bent it further than 90 degrees -- so it's pretty stressed right there.  Moreover, for a while I just had the tank shoved in there, and it was that tube that was holding it in position (I've since started shoving in bits of foam to space it away from that wall of the tank compartment).  So it was stressed and sustaining some vibration.
It got me to wondering, though -- I'm using a cheapo metal brake that bends the metal over a sharp edge -- should I be intentionally radiusing the bends?  If so, by how much?  1/16", 1/8"?  The inner radius is probably 1/32" or so currently.  I'm using K&S tinplate.
This is the first time this has happened to me.  It's maybe only the fifth or sixth tank I've built, and by no means the one with the most miles on it, but it's the first one that's in a full-fuselage model.
What do you experienced tank home-builders do?
Re: Stress Cracking in Tin Tanks
« Reply #1 on: September 10, 2018, 12:27:12 PM »
  This is a pretty rare issue with the mild steel "tin" tank material I use (K&S) and I do nothing in particular to reduce the tendency.
« Reply #2 on: September 10, 2018, 12:47:46 PM »
Thanks, Brett.  I was hoping I'd get an answer from you, because I know you build your own tanks.
The crimp where it broke was pretty severe, and as I noted the stress may have been exacerbated by letting the tank ride on the tube.  I patched the thing (and pressure tested!), and won't try to locate it by the tube any more. Hopefully I'm set.
Offline Dane Martin
  • heli pilot BHOR
« Reply #3 on: September 10, 2018, 01:54:59 PM »
Buy plastic clunk tanks
Joking aside, I've only "built" tanks for speed planes and they were kits. Bends were already there. I just had to solder them together.
« Reply #4 on: September 10, 2018, 01:57:34 PM »
Oh thank you.  The tank in question is a clunk tank, but that's because when it comes to getting a fixed-inlet metal tank working, I ride the short bus.
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: September 10, 2018, 02:24:15 PM »
That's specifically the reason I buy plastic tanks. I'm "getting it" now, and I've been successful at helping others set up theirs, and get their engines running. But I'm still scared to use metal tanks myself.
« Reply #6 on: September 10, 2018, 02:35:36 PM »
Besides, if I wanted a blow-molded plastic clunk tank in that tank compartment, I'd have to custom blow-mold it myself.  I think I can do a tin tank quicker and easier.
Offline Dane Martin
  • heli pilot BHOR
« Reply #7 on: September 10, 2018, 03:05:32 PM »
There's been times I've struggled to find a tank that fits. I've wondered if it would be worth figuring out a couple tank sizes to mold. But it would be a healthy investment in time and equipment to make some tanks for me and a couple dudes.
Offline Lauri Malila
« Reply #8 on: September 10, 2018, 03:27:57 PM »
Tim,
As bending tools, I only use hard wood, like engine bearers and such. Much less risk to damage the tin plate with those. I don't think you even need to think the corner radius with wooden tools.
Not exactly what you experienced but only time (maybe 20 years ago) I have had stress cracks, it was in bottom corner in rear of tank.
Since then I have started to use a baffle in tank, about an inch in front of rear wall.
Maybe a baffle makes engine run better, difficult to say, but for sure it stops the top & bottom walls from resonating and cracking at corners.
My tanks work well but I can't make them very light, maybe it has saved me from bigger trouble. L
« Reply #9 on: September 10, 2018, 05:05:52 PM »
Lauri:
I really like the accuracy I can get from my bender.  But it occurs to me that the one bit that the metal bears against when bending could be replaced with wood!  (It's a really cheap bender -- you bend against a bar that you clamp on).
I'll probably try bending against wood as you suggest, and if I don't fall in love with it, try a wood bit in my bender.
« Reply #10 on: September 10, 2018, 05:41:43 PM »
   The K&S stuff is handy and reasonably priced but it can fracture and it's best to have at least a minimal radius at the bend. Jim Lee makes a really neat hand held tool for bending metal tank parts, and I have used maple motor mount stock, as has already been mentioned.  I use a mixture metal and plastic tanks, depending on the airplane and room constraints. One is as good as the other. Both have advantages and draw backs, you just have to understand that and work with in their limitations.
« Reply #11 on: September 11, 2018, 12:50:17 AM »
Tim,
You can safely bend annealed mild steel with a bend radius of only 1/2t or so. If you used K&S #254 material, which is only .008” thick, that gives you a radius of only .004”. That is small.
If you used metal tools to make the bend, they probably were deburred if made by machining. That is likely going to be a softer edge than your requirement. If you used a Lee bender, these appear to be made of cold rolled steel and the edges come from the steel mill softer than that. On the one that I bought I left the sharpest edge so I could use it, and then softened a couple other edges to use on thicker material and material with higher temper.
For making tanks in general, I actually prefer a set of wood bending tools (hand seamers) that I made. These are not form blocks that look like a tank and you hammer your metal parts overtop that. I detest that method….
I do the layout work with a Sharpie pen. The use of a scriber is prohibited in aerospace work. It should be for models, too. A scribed line is a great place for cracks to initiate. I assume you didn’t do that.
Out of curiosity, tonight I made up two hemmed samples. I first formed a 90 degree bend using the Lee tool, on the sharpest edge. Then I closed the bend solid in a vise. The vise has aluminum pads on the jaws. The result is a hard 180 degree bend with essentially zero bend radius. Ok, it is not really zero, but is not measurable without sectioning it and using a microscope. I made one sample with the bend across the material grain (recommended practice for minimum radius bends) and one along the grain (fine for standard radius bends and larger). Neither sample cracked.
One way to cause early failures is to form and reform bends during fabrication. This causes so-called “low cycle fatigue.”  If you didn’t do that, then my thought is that your problem was vibration. This can be compounded by installing the tank with stress on it, and then superimposing cyclic loads from vibration.  So I think floating the tank is a good idea. I don’t like tank vents attached to the fuselage. I hard-mount a separate fitting to the side of the fuse and then connect to the tank with flexible line. Control the stress and you control the failures….
I’ve actually had more plastic tanks fail than metal ones. I think the newer tanks are better, and the use of the cap to help control the rubber stopper forces is what made plastic tanks reliable enough to be worthwhile.
Good luck with your tanks,
« Reply #12 on: September 11, 2018, 10:36:16 AM »
If you're going to custom build a plastic tank you can "weld" it yourself with a soldering gun and maybe a variable power supply.
It's not any easier than building a metal tank but I've resized several Sullivan tanks myself.
« Reply #13 on: September 11, 2018, 02:14:33 PM »
Phil,
Any luck repairing split-neck Sullivans with an iron? Or should I box all of mine up and hope the guarantee is good?
"Divot" McSlow
« Reply #14 on: September 11, 2018, 02:27:02 PM »
I use a scriber if I want a nice straight cut with an edge that can be cleaned up with one swipe of a file.  But not for bends, no.
My dad's company built parts for Rolla Vollstedt Indy car efforts in the 60's.  The first go-around, they built the fiberglass bodies over the fuel tanks, and trimmed the fiberglass by running the knifes against the aluminum tank.  I'm told that when the tanks fell apart on the track, it looked like they'd been sheared.
« Reply #15 on: September 11, 2018, 09:48:14 PM »
Ouch!
Offline John Jordan
  • Balsadust
« Reply #16 on: September 12, 2018, 12:33:03 AM »
     Put tubing in, place a washer over tubing, solder, twice the thickness stronger never use tubes to support the tank.
John Jordan    ama # 5939
« Reply #17 on: September 12, 2018, 12:48:49 AM »
No washers are necessary when you don’t drill the hole for tubing but rather poke it with sonething like sharpened piano wire with correct diameter.
It keaves a nice radiused ”fillet” to tin plate. L
« Reply #18 on: September 12, 2018, 07:37:56 AM »
I am not sure what is happening, but using completely conventional techniques on maybe 100 tanks over the years, I haven't had any of these issues. I poke the holes for the tubes with a sharpened 8p nail, no reinforcement is necessary, and I bend them at tight as I can manage with no radius.   I have also seen no one else have any problems with stress cracks in the steel. I do sometimes see problems with the solder cracking, but only when the tubes are not properly soldered on the "loose" end inside the tank.
   Of course, if you are doing something absurd like using Dykem Blue and scratches, it will probably have issues, but you don't want to do that. What I do is draw the tank (by hand or CAD), all flattened out, print it out, then use 3M77 to stick it to the metal. Cut where it needs to be cut (with quality stainless-steel SCISSORS, not tin snips or workshop tools), bend where it needs to be bent, as sharp as you want, then remove the paper with lacquer thinner. Clean it all up, solder it together, move on with life.
   Far and away the biggest issue I see routinely is the workmanship on the solder joints, usually by wrong techniques, like torches, scratching it up with abrasives, acid flux, etc, or other barnyard/high school shop class approaches. You need only a decently powerful soldering gun and 60/40 rosin core solder and clean material to begin with, and good soldering technique.
