  • July 03, 2025, 10:46:32 AM
Author Topic: Evo .36 C/L or R/C?  (Read 1110 times)
Offline Balsa Butcher
  • High Desert Flier
Evo .36 C/L or R/C?
« on: September 02, 2010, 03:22:52 PM »
I'm asking this for a friend. Is there any way to determine (with the engine disassembled) if the P&L of an Evo 36 is the R/C version or the C/L version. I know there is a difference. Thanks in advance.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Dave Adamisin
Re: Evo .36 C/L or R/C?
« Reply #1 on: September 02, 2010, 03:57:45 PM »
C/L has only two transfers...
  • High Desert Flier
« Reply #2 on: September 02, 2010, 04:24:31 PM »
Thanks Dave, I was hoping this thread would catch your eye. FWIW: My Evo runs great, still using the remote NV but an OS RC NV is waiting in the wings. Best to your Dad.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Tom Niebuhr
« Reply #3 on: September 02, 2010, 05:55:29 PM »
Pete,
Did you have to do anything to the Evo .36 remote needle valve set up? Is it in a upright or inverted postion or is it on a profile?
AMA 7544
  • High Desert Flier
« Reply #4 on: September 02, 2010, 07:06:18 PM »
It's just on a profile so the position of the spray bar doesn't make any difference. I don't plan on using it in a full bodied plane only because I have other comparable engines that work well and don't need any special airframe mods.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Leonard Rennick
« Reply #5 on: September 02, 2010, 11:52:31 PM »
You don't have to disassemble the engine, just look through the exhaust port. If there is a port straight across, then it's an RC engine.
Leonard
Leonard Rennick AMA 865846
  • High Desert Flier
« Reply #6 on: September 03, 2010, 06:25:59 PM »
Thanks all for the input. P & L have been determined to be the C/L version as we had hoped. Engine was received disassembled without carb which is why the question was asked. Some very impressive internal workmanship evident...large brass conrod bushings w/tapered oil holes among other features. Now to put it back together... 8)
Pete Cunha
Sacramento CA.
AMA 57499
Dave Adamisin
« Reply #7 on: September 03, 2010, 08:50:48 PM »
Good to hear. I beat the heck out of mine and it's still going. I've been running the 60 more lately. I flew it to a second place at the Signal Seekers contest. Big is coming over to watch football with my son Mike and I tomorrow. Go Blue.......
