  • July 05, 2025, 10:25:36 AM
Author Topic: Bubbles in fuel line??  (Read 4142 times)
Offline frank mccune
« on: July 20, 2023, 02:12:03 PM »
     Hello All:
     After flying our session today, I mentioned to my mate that I would like to eliminate bubbles in my fuel line.  He suggested that it was just a part of operating a glow engine and just accept it.
      My question is this.  Is this true, how can I eliminate these pesky annoyances that prevents a smooth engine run?
       Suggestions/comments
       Tia,
       Frank McCune
Offline realSteveSmith
Re: Bubbles in fuel line??
« Reply #1 on: July 20, 2023, 07:18:23 PM »
If you are using a plastic tank (Dubro,Sullivan, etc), there are aftermarket clunks that have been shown to reduce the bubbles in the supply line.
OS ENGINES Bubbleless Clunk  (https://gravesrc.com/osm71531000-os-engines-bubbleless-clunk/)
Dubro Tank Filter  (https://gravesrc.com/dub161-dubro-tank-filter/)
MIRACLE RC IN TANK FILTER CLUNK  (https://gravesrc.com/mirh-013-miracle-rc-in-tank-filter-clunk/)
Take note that I'm new to CL Stunt but I've been playing with model engines (Mainly RC Stuff) since the early 80s.  I don't know if any of these suggestions will transfer to use in a stunt model, but I've seen them make a difference in RC models (mainly helicopters).  They may be worth a try.
In my experience, bubbles in your supply line usually indicate fuel foaming that is caused by vibration.  Reducing the amount of vibration that the tank experiences would be the best fix and I'd exhaust all possibilities here before trying a fancy clunk.  All the obvious stuff applies....use a well balanced prop...ensure that the nose of the model isn't overly flexible...isolate the tank from the air frame with foam rubber...etc.
Finally, I have heard tell of people adding substances to their fuel to reduce foaming.  Ive read that adding Armor All (not sure of the amount used) to the fuel can reduce foaming/bubbles in the line.
Make sure to report back if you try any of this.  I'd like to know if any of it helps.
AMA 175438
« Reply #2 on: July 20, 2023, 09:41:42 PM »
I have noticed that a filter will stop any trouble the bubbles might make.  With out a filter I could not get a setting. D>K
« Reply #3 on: July 21, 2023, 09:03:36 AM »
   You will not eliminate 100% of the bubbles, but can get rid of enough of them to make needle settings easier. First thing is to make sure your props are as balanced as good as you can make them. You won't eliminate all vibration, but every little bit helps.  Fuel filters are discussed for their obvious benefit of stopping junk from getting to the needle but they can strain out air bubbles also. If you use one of the larger units, it gives a place for the air to accumulate and nothing but fuel gets to the needle. I have used Armoral in the past with no problems. You just add a tiny little squirt to a jug of fuel, and I'm talking about just a few drops, then shake it up and you should not see any foaming action. This doesn't last forever but will get you through a flying session. I have demonstrated this to several R/C guys while flying at Buder Park. One guy had a neat 1/2A jet with a Cox TD-051 mounted in a pusher configuration. It would just not peak out the ROM he needed to get it airborne from a hand launch. I talked him into trying a dab of Armorall and promised to buy him a new jug of fuel if it didn't work. He fired it up again, and it was night and day different. he had enough power to get it in the air and fly it, and he could visibly see no air bubbles in the fuel line to the engine. It's easier to just eliminate the source of the foaming, which is vibration from an out of balance prop or loose engine mounts, and get the best fuel feed that you can. Brett has discussed doing what you have to do to get larger fuel lines in your tank and fuel feed to the engine on larger models and this can help out a lot I think. Go to 5/32" tubing for all the tank fittings and large fuel line stepped down to the medium you need at the NVA nipple. I intend to play with that concept when I get back to flying my larger models.
« Reply #4 on: July 22, 2023, 03:11:30 PM »
I'm with Doc. I was going to ask if you have a filter in the line feeding the NV? The only tank vibration problem I've ever experienced was a dead lean flight at 4.2 sec. laps. Not fun at all, I might add.  n1 Steve
Offline Paul Van Dort
« Reply #5 on: July 24, 2023, 02:47:28 AM »
Please make sure the uniflow exit in the tank is not too close to the fuel pickup. Some tank designs are very risky wrt to bubbles in the pickup. Also RC tanks with 2 clunks can give bubble issues...
« Reply #6 on: November 07, 2023, 05:18:34 PM »
While I can see how these two 'filter' clunks would work fine for R/C, I don't see how they would be a good thing for CL Stunt. It seems to me that once the clunk is even partly uncovered (with fuel), then the engine would quit with fuel left in the tank. Would it be consistent is the real problem, but also, if there's fuel leftover in the tank, it would probably make getting your fuel load consistent, which isn't a good thing with our flight time limit.
With R/C, on the other hand, it's usually considered a bad thing to let the engine quit before landing. I'd also wonder if they might eventually get clogged, and if they could be cleaned without buying an ultrasonic cleaner. I think you'd want the smallest and heaviest clunk you could find or make. I also think you want a fixed uniflow tube if you hope for consistent engine speed for inside/outside tricks. I've used clunk tanks on three models, IIRC, and not likely to do that again. D>K Steve
Offline John Miller
« Reply #7 on: November 07, 2023, 08:52:54 PM »
Hi Steve
I've used the Dubro sintered bronze clunk filter (middle link above) since the early 90's. Your fears about the engine starving out, with fuel still in the tank, just have not happened to me in all that time. My tanks are empty of any fuel at the end of a flight. I also use the same style of filter in my fuel jug pickup line. I like the idea of prefiltering the fuel before it is put in the tank, just because I'm a little obsessed with having clean fuel. It seems to help keep the engines running as they should.
Most of the tanks I use are RC plastic tanks converted for CL use and run with a fixed, non-moving, not connected to the clunk, uniflow venting arrangement. I have had the best success with that style of venting.
There's another benefit that comes from this arrangement. I make 2 small bends in the uniflow line. The first one will go inside the tank to position the end about the middle of the sidewall. The second one will be made after the tank is assembled. Experience has taught me that this bend does not need to be more than about 30-45 degrees, it's only there to help you move it, up or down.
Moving it up or down, effectively changes the relative height of the tank, without having to physically move it.
I believe that when the uniflow vent end, inside the tank, and the clunk pick-up are connected, your relative apparent tank heights could change every time the clunk moves up or down. Perhaps this may be part of the reason some people have a bad taste in their mouths when trying to use a plastic uniflow tank.
There are several other advantages inherent to using plastic tanks.
RC plastic tanks are usually less expensive and more readily available.
No soldering is involved, with the problems of bad joints, and residue inside the tank. Having to desolder to see, or correct problems inside.
Depending on the brand and type, some are easy to see inside. In any case, they are easily opened up should the need arise.
You can simply swap out the annealed, brass tubing for copper tubing to avoid the brass tubing cracking, or splitting from reaction to our fuels. This can be accomplished as you assemble the tank the first time.
Easy tank height adjustment as detailed above.
One of the possible cons could be trying to use a style of plastic tank that may not work for your setup. Unless you have no need to adjust your tank height, I suggest you not use the slant front style for stunt. It is difficult to impossible to properly raise or lower your apparent tank height with that style of tank. I prefer the rectangular style with the tubes coming straight out the front. Other styles can work as well, as long as the stopper has the tubing, outside the tank, aligned parallel to the top and bottom.
I apologize for the thread drift and the length of my reply. In a way, it does have relevance to the subject matter. The sintered bronze-style clunk pickup has been shown to have helped some with minimizing bubbles in the fuel line. Split or cracked brass tubing in the metal tank will, at the least cause bubbling. There have been more than a few posts relating to this on the forum.
If desired, I can dig out the CAD drawing I did that shows how I set my tanks up and repost it. It was Allen Brickhaus, who passed several years ago, who showed me how to set up a plastic RC tank for stunt work. I made a few modifications to make it easier to use and since then, with 1 or 2 exceptions, that's all I use.
John Miller
« Reply #8 on: November 08, 2023, 04:56:29 AM »
They actually do a much better job of emptying the tank than a standard clunk.  Try one for yourself and see.
AMA 175438
Offline Steve Glass
« Reply #9 on: November 09, 2023, 01:48:46 AM »
The double clunk tank works for me. Don’t know why it works, but it does. Indeed, I’ve tried every other tank arrangement with little success. I only fly profile models, maybe the double clunk is a good solution for profiles?
Another thing. I use a nice solid piece of angled aluminium as a shelf to mount the tank. the tank height can be accurately shimmed up ur down with thin ply strips. Accuracy to within 1/32” is needed for final adjustment.
« Reply #10 on: November 09, 2023, 05:35:53 AM »
There should not be any bubbles in the fuel line. None. it makes correct needling impossible and engine runs erratic.
- In the tank, make sure the uniflow is well separated from the pickup. E.,g. Uniflow close to the front of the tank, pickup at the rear. There is no need whatsoever to have them close to eachother
- Make sure your fuel is not foaming. Reduce vibrations by balacing props, make a sturdy nose and put a drop of Armor All in the fuel to cancel foaminig
