  • June 26, 2025, 01:30:04 AM
Author Topic: Size of Veco .19 ?  (Read 1564 times)
Offline YakNine
Size of Veco .19 ?
« on: November 02, 2011, 06:02:40 AM »
I am curious about the size of a Veco .19 is it a lot smaller than a .35 , I have a McCoy .19 and was wondering if it was about the same size externally Thanks T.J.
AMA 85135        GSCB
Re: Size of Veco .19 ?
« Reply #1 on: November 02, 2011, 10:39:19 AM »
Hi TJ,
The size of the Veco BB 19 is very close to the McCoy .19.  I can't swear that they ill fit the same mounting holes, but overall size is close.  The plain bearing Veco .19 is basically the same overall size as the BB version.
Offline L0U CRANE
« Reply #2 on: November 04, 2011, 12:15:15 PM »
They are pretty close, and you'll notice a difference in front overhang and needle valve location.
I did a check several years ago, and a whole lot of engines in the .19 to .40 range have close to the same mount hole spacing. There are differences in width, and both front and rear overhang, but a "generous" bolt hole clearance in the motor mounts will fit (sloppily) lots of engines...
\BEST\LOU
Offline YakNine
« Reply #3 on: November 04, 2011, 01:50:08 PM »
I am thinking about a Flite streak ARF and powering it with the Veco .19 I am so busy lately that I am thinking about going the ARF route so I can at least get a little flite time in Living in a tiny apartment with no place to build doesn't help either. Thanks T.J.
AMA 85135        GSCB
Offline Annette Elmore
    • Lots of UK-related stunt stuff
« Reply #4 on: November 05, 2011, 03:23:10 AM »
Engine tests for these are on my site:
Offline YakNine
« Reply #5 on: November 05, 2011, 09:44:19 AM »
Thanks for the info Annette I enjoyed reading the reviews. T.J.
AMA 85135        GSCB
« Reply #6 on: November 05, 2011, 12:27:15 PM »
    I also live in a tiny apartment and have had only minor difficulties, so it can be done. As long as you have a high tolerance for disarray, and you live alone.
   Flite Streak/Veco 19bb is a great combination. Run an APC 9-4 or 10-4 to start.
Offline YakNine
« Reply #7 on: November 18, 2011, 08:15:55 PM »
Hey Brett I don't live alone but I am setting up a tool shed / man cave out in the yard soon I can't afford a 2nd ex-wife! T.J.
AMA 85135        GSCB
Offline YakNine
« Reply #8 on: November 28, 2011, 05:14:17 PM »
I picked up an R/C engine with an Enya muffler on Ebay real cheap and it looks very promising lots of castor goo on it but excellent compression . I read the reviews above from Annette and saw that the needle valve was the same for R/C and C/L and low and behold it was , plus I picked up an N.O.S. venturi at a swap meet yesterday for 8 bucks and a old flite streak kit for 35 bucks. The Enya muffler is new and would not work with the throttle valve installed but it fits fine with it removed , it's nice to get lucky once in a while! T.J.
AMA 85135        GSCB
