  • June 25, 2025, 09:48:45 PM
Author Topic: Bru Line Filters  (Read 1538 times)
Online Geoff Goodworth
Bru Line Filters
« on: November 27, 2011, 04:07:39 PM »
What has happened to Bru Line Filters? I can't seem to find any whole filters.
Offline Mike Greb
Re: Bru Line Filters
« Reply #1 on: November 27, 2011, 04:19:39 PM »
I think they are out of production.  If you look around you can find the filter parts, but the rubber part seems to be almost impossible to find.  Too bad, that was a great product that fitted my needs exactly.   The blue line filters worked well, I would ca them together and then put some heat shrink tubing on the outside, after that they never would come apart.
Offline Paul Allen
« Reply #2 on: November 27, 2011, 10:51:10 PM »
Yes, another good product gone! Sign of the times.
Paul  ''
Offline Don Curry AMA 267060
« Reply #3 on: November 28, 2011, 08:44:41 AM »
In the r/c car section at your hobby shop you will find air filters for the fuel engines that are useable though larger than the Bru-Line type.
Offline Balsa Butcher
  • High Desert Flier
« Reply #4 on: November 29, 2011, 03:26:41 PM »
or you could use a swatch of nylon stocking held on by a faucet "O" ring. 8)
Pete Cunha
Sacramento CA.
AMA 57499
