Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
June 21, 2025, 04:15:47 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
NVA
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: NVA (Read 812 times)
John KruziK
25 supporter
Trade Count:
0
Commander
NVA
on:
June 22, 2007, 07:19:03 PM »
I have a fox 25 and was wondering where exactly the hole in the needle valve should point. Some engines have it facing straight down, others have it facing forward. Which way is correct Thanks John
Logged
AMA 874027
Marvin Denny
Trade Count:
0
Captain
Welcome to the Stunt Hanger.
Re: NVA
Reply #1 on:
June 22, 2007, 08:25:08 PM »
Pretty well straight down toward the crankshaft or parallel to the air flow down the venturi. It is not really critical as long as it is somewhat close to downward toward the crank shaft.
Bigiron
Logged
marvin Denny AMA 499
Tom Perry
Trade Count:
0
Captain
Re: NVA
Reply #2 on:
June 22, 2007, 09:04:36 PM »
Turn the spraybar untill you can see the hole. Then turn toward the front until you can no longer see the hole when looking straight down. Think of a perfume atomizer and how it works.
Logged
Tight lines,
Tom Perry
Norfolk, Virginia
John KruziK
25 supporter
Trade Count:
0
Commander
Re: NVA
Reply #3 on:
June 23, 2007, 06:50:48 AM »
Thanks for tips John
Logged
AMA 874027
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
NVA
