  • June 24, 2025, 09:12:08 AM
Author Topic: Brodak 40 : Best Props ?  (Read 1793 times)
Offline Robin_Holden
« on: April 20, 2010, 01:46:53 AM »
Greetings fellas from a sunny [ at last ! ] S.W.France.
My Brodak 40 has been carefully run-in.
It's installed in a Sig Banshee and ready to rock n'roll.
My fuel is 5% nitro , 24% lube' [ 50/50 ]. Uniflow plastic tank .
What would be your recommended prop' please ?
Oh..... It's a great engine by the way .
Much obliged for any contributions ,
Robin [ ex-pat Brit in the Charente full of ex-pat Brits ]
Offline Bootlegger
Re: Brodak 40 : Best Props ?
« Reply #1 on: April 20, 2010, 05:05:28 AM »
Mornin' Robin, I have been runnin' mine with 5% nitro and a 10x5 APC prop, seems to like it real well..
      Hope that this helps... D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline David Shad
« Reply #2 on: April 20, 2010, 06:04:58 AM »
I have found the Master Airscrew 11X4 works great on mine in a Nobler and Smoothie both at 42 oz.
Big Dave AMA 80235
« Reply #3 on: April 21, 2010, 09:02:43 AM »
So far I am sold on the Top Flite Power Point 11-4 wood blade.  Have tried the APC 11-4 and it is heavy.  Zinger 11-4 is too thick.  Master Airscrw 11-4 wood is the nxt best prop, just need to order some more of them.  By the I use Excalibar 10% with 22% oil(1/2 & 1/2).  Also run in a rich two stroke mode. H^^
Offline Balsa Butcher
  • High Desert Flier
« Reply #4 on: April 21, 2010, 01:32:05 PM »
The two best B-40 props that I have found are the APC 10.5 x 4.5 and the Thundertiger 11X4.5.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Allan Perret
  • Proverbs
« Reply #5 on: April 21, 2010, 04:04:50 PM »
My B40/NoblerARF really likes the Zinger wood 11-5 cut down to 10.5.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: April 22, 2010, 01:10:22 AM »
Much obliged guys for all your contribution , many thanks.
Robin.
« Reply #7 on: April 22, 2010, 03:42:18 PM »
Cyclone 11 x 4.5 is an excellent  cheap prop for the Brodak 40 and many othe rmotors
« Reply #8 on: April 22, 2010, 06:04:20 PM »
I've watch Pete Peterson flying his Rondenelli Venus with a Brodak 40 and the Cyclone 11x4.5 prop for awhile. Great setup.
Offline Mike Ferguson
« Reply #9 on: April 23, 2010, 08:14:09 AM »
Top Flite 11-4 works brilliantly in mine.
