  • August 03, 2025, 06:24:06 AM
Author Topic: What model OS 25 is this?  (Read 4849 times)
Offline Chris Fretz
« on: May 23, 2016, 07:16:20 PM »
Could you guys educate me on what kind of OS 25 this is? Do you run it like a LA25 (prop,rpm,fuel)?
Formerly known as #Liner
AMA 1104207
Advanced
Offline Jim Oliver
Re: What model OS 25 is this?
« Reply #1 on: May 23, 2016, 07:54:30 PM »
.25 FSR?
Jim Oliver
AMA 18475
Offline Chris Fretz
« Reply #2 on: May 24, 2016, 06:22:04 AM »
.25 FSR?
You may be on to something there!
AMA 1104207
Advanced
« Reply #3 on: May 24, 2016, 09:10:05 AM »
dual ball bearing engine, will produce a huge amount more power
« Reply #4 on: May 24, 2016, 10:33:56 AM »
     I think it's a 25SF. A lot more power than a 25LA in general. I wouldn't expect to be able to keep the airplane below the sound barrier with any commonly available props with a stock 25LA venturi. Maybe something like a really light 11-4 and a smaller venturi, but I doubt it would have the kind of maneuvering response you get with the 25LA.
   It could probably work nicely piped and I recall Darrell Harvin with a very similar setup back in the early 90's (maybe a 32 instead of a 25).
Offline Chris Fretz
« Reply #5 on: May 24, 2016, 12:09:28 PM »
Thanks Randy
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #6 on: May 24, 2016, 12:11:44 PM »
Doesn't sound like this engine is going to do much for me then...
AMA 1104207
Advanced
Online Fredvon4
  • Central Texas
« Reply #7 on: May 24, 2016, 01:30:37 PM »
Build any good combat ship ...easy fasted way is a Phil Cartier Core House fast combat plane like the GOTCHA STREAK III  and stick that sucker on with a 8x8 prop, bladder fed, 15%N 20%oil 50/50 ad hold on! ...loose the muffler
Put it on the nose of a Core House Rugged Stunt trainer with a thin low pitch prop 10x3 add some tail weight
Fred von Gortler IV
« Reply #8 on: May 24, 2016, 03:41:02 PM »
  Need a bigger airplane than a Tomahawk, that's for sure. Fred's suggestion is a good one.
« Reply #9 on: May 24, 2016, 03:53:05 PM »
Thanks Randy
GOOD  Nobler  motor, use a 10 x 4 pro Z   or similar
« Last Edit: May 24, 2016, 04:25:49 PM by RandySmith »
Offline Jim Oliver
« Reply #10 on: May 24, 2016, 04:15:03 PM »
I think the 25 SF cases were identified with "SF" as part of the casting.
Either one, FSR or SF, is a screamer.........
Jim Oliver
AMA 18475
Offline Chris Fretz
« Reply #11 on: May 24, 2016, 04:31:38 PM »
Thanks for the info fellas.
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #12 on: May 24, 2016, 07:03:08 PM »
Is a 25FX in the same boat as this engine?
AMA 1104207
Advanced
Offline Akihiro Danjo
« Reply #13 on: May 24, 2016, 11:26:55 PM »
It is FSR25. I have run mine with almost the same setup as FP/LA25s for Doodlebug.
6.8mm venturi with 4.0mm NVA, less restrictive muffler, APC 9.5 X 4 (cut 10-4) and 10% nitro 23% all syn fuel. I felt it had a little more power than FP/LA. It can be opened the venturi a little to get more power with steady run but need a larger tank.
Aki
« Reply #14 on: May 25, 2016, 12:21:48 AM »
yea , FSR definately . used a clone ( Magnum 25 pro ) lots in a Nobler Sized thing .
9x6 or 10 x 6 worn to 9 1/2 , trike gear so the grass ronded the tips le nicely after
Id tried a few touch & Goes up the resivoir on the concrette in the wind .Impossable
to touch but was a bit of force in the wind .Tornado Props , the flexi 10 x 6 it bogged
a bit till it wore down .dunno if it was a black 9 x 6 or 9 x 4 for a blow , likely both ,
at times .
21/35 in it there , but mustve gone over 10 gallons thru the .25 in it . 52 span & 45 + Oz.
a quick wipe with a rag & petrol took a hour and a half , at one stage - when it'd got a bit
gooked up . Mine had a Fox bb 119/25 CL intake, so the needle was level with the outside of the fuel tank .
Got it rich down low & lean up the top of the circle . A bit gutless for it but kept you on your toes .
Magnums identical internally .
about OS 35 S performance .
used 55 ft. of .018 when it was blowing , but ive had that motor on 70 ft of 016 solids and it cruised along ok with a big sag in the lines ,
still drag itself over the top of the circle etc .
A Don Still Stuka would be ideal for it .
