  • June 22, 2025, 03:25:46 AM
Author Topic: Bolly Prop  (Read 1293 times)
Offline Gene O'Keefe
Bolly Prop
« on: October 31, 2008, 01:07:19 PM »
What is the best Bolly prop for a ST .51 and a ST .60 (both T&L reworks) - either a 2 blade or 3 blade ? ( or ? 4 blade ?) -- [ kits are Hawker Hunter for the .60 and Sig magnum  for the .51]  - thanks for all responses.
Geno
Gene O'Keefe
AMA 28386
Offline Crist Rigotti
Re: Bolly Prop
« Reply #1 on: October 31, 2008, 01:41:33 PM »
I use a Bolly 13 x 4.25 repitched to 4.5 2 blade on my T&L ST 51 with excellent results.
Offline Greg L Bahrman
Re: Bolly Prop
« Reply #2 on: October 31, 2008, 01:50:33 PM »
I like the APC 12 1/4 x 3 3/4 on my ST51 as recommended by Dan McEntee.
« Last Edit: November 02, 2008, 09:19:31 AM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Re: Bolly Prop
« Reply #3 on: October 31, 2008, 01:52:06 PM »
Geno
Hi Geno
Many people use  the 12 x 6 2 blade  12.5 x 5.5 2 blade or  as Crist says the 13x4.25 2 blade, on the  ST 51. I used a Bolly 12x6.5n on the 51 in a Mgnum with good results, My personal recomendations would be the 12.5 x 5.5 or the 12 x 6.5N 3 blade
The ST 60  most people used the  12x6.5N 3 blade 12.5 x 6.5 3 blade or the  Bolly 13 x 6 2 blade, some people use the 13 x 6 depitched to 5.5 or 5, That seem to be the best prop I have ever used on a ST 60
Jimmy Casales  had a very good performance with the 12 x 6.5N 3 blade on his ST 60s, Bill Rich ran the 13 x 6 for years
Billy Suarez uses a Bolly 13 x 6 depitched to 5, or 5.5, so take your  pick
Bene Rodriguez from Brasil used a Bolly 11 x 7 4 blade on his ST 51 on the Amozon stunter and got great results.
Offline Steve Fitton
Re: Bolly Prop
« Reply #4 on: October 31, 2008, 09:02:28 PM »
What were people pitching the 12x6.5 3 bld down to for the ST 60s?  5.5 or 5?
Re: Bolly Prop
« Reply #5 on: October 31, 2008, 09:16:01 PM »
Hi Steve
Jimmy and most others used it as is. The props is actually about a 5.7 pitch the way it comes from Bolly, and the ST 60 likes to run in a fat 4 cycle, this is on a "normal type 60 size ship" if you have a skinny thin wing plane it would work well at 5 to 5.5
