  • July 15, 2025, 05:21:27 PM
Author Topic: Bent PA Needle  (Read 1241 times)
Offline Leester
Bent PA Needle
« on: September 13, 2006, 05:46:06 PM »
Several weeks ago I had an incident, the ground was to close to my plane. The only damage was a bent needle. Can this be straightened and still be good, or it it toast. Thanks  Also could this damage the valve assembly? ??? ???
Leester
ama 830538
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Bent PA Needle
« Reply #1 on: September 13, 2006, 06:40:12 PM »
Toast!!!!!!
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Online RC Storick
Re: Bent PA Needle
« Reply #2 on: September 13, 2006, 07:16:08 PM »
Throw it out and get a new one. It will never needle right again.
Offline Ward Van Duzer
Re: Bent PA Needle
« Reply #3 on: September 14, 2006, 06:07:35 PM »
Call Randy! Order 3 or 4. They won't break you,,,,,and they'll save you hours of frustration! Really!
