  • July 15, 2025, 04:09:13 PM
Author Topic: Need a spot of help please.  (Read 1160 times)
Offline Bob Johnson
  • Lone Eagle Stunt Flyers -Have stooge. will travel.
« on: September 13, 2006, 10:04:23 AM »
I had a strange thing happen to me while flying in Peoria. On my second round flight things were going along just fine until the overhead eights. Suddenly the motor sagged/went rich, I nearly lost the plane but managed to save it by the skin of my teeth. The rich run continued till the lean out at the end of the tank. I'm running an OS 20fp in the BBTU set up. This has been a consistant and problem free performer. The practice an first round flights were trouble free. The only change I made was to use one eighth ounce less fuel to shorten the flight a bit. I have not had it back in the air yet, but have looked it over and can find no problems. I can think of a lot of things that would make it go lean, but not rich. The fuel I'm using is a 50/50 blend of Sig 5%-25 all castor and 10%Tower power(I know, but it's worked well all season so far) Any ideas of whats going on? I'll post a photo of the set up,  the only change from the photo is the addition of a check valve between the muffler and tank. Thank you in advance for your help.
Bob
Offline Tom Perry
Re: Need a spot of help please.
« Reply #1 on: September 13, 2006, 10:17:44 AM »
Although it seems unlikely, I'd change the glo-plug before trying anything else.   #^
Tight lines,
Tom Perry
 Norfolk, Virginia
« Reply #2 on: September 13, 2006, 11:44:53 AM »
HI Bob
As  stated  change  the glo plug, and  be  aware  after  cranking  if the engine  sags  a little  when you remove  the battery.  This can indicate  a  plug going  bad, or  a  plug that is   too  cold  for the motor . Also  you would want to  clean the  filter  spray bar  and  NVA  assembly.
Offline L0U CRANE
« Reply #3 on: September 13, 2006, 11:48:37 AM »
A few other thoughts:
Check to make sure the intake filter is clear and clean...
The check valve only admits pressure to the tank, I'd guess. An open line from muffler to tank doesn't *hold* pressure. If the engine spins up a bit high, and some excess pressure goes to the tank, a check valve would prevent it from venting back through the muffler.
(Seems that should only be a temporary thing, tho, doesn't it?)
Be interested to hear what does the trick for you.
\BEST\LOU
