Two (healthy) washers, for the long reach plug?
Oh, true, can shim plug. I took that photo some time back to show what the head portion of the combustion chamber looked like.
[THREAD HIJACK]
Not using these Fireballs any more. I got a card of a dozen NOS Fireball plugs made some time ago may be 5 years ago off E-Bay, but alas, something's wrong with their catalyst coating. Works good first day out of the box. Wait a week, barely lights off and sputters. Never had that happen to me before with these plugs back in the late 1970's. They worked excellent especially for smaller A-size RC engines, from idle to full power. Looks like Swanson for this batch got a bad supplier of platinum coated nichrome wire. Yet the venerable Enya 30 plug that came with the engine fired right up no problems at all.
Seeing the heading is merely ' McCoy ', rumour has it the Merco 49 internals are near compatable with the Mc coy 49
Oh, wouldn't surprise me. Amazing some of the things folk have discovered. Example, I found that Evolution .46 rear needle valve assembly worked excellently on my McCoy .35 Red Heads, plugged needle valve side of the spray bar with a 2-56 screw, run fuel line to Evo RNVA, which bolt spacing fits backplate screw distance perfectly. Has a finer thread for easier tweaking of the mixture plus O-ring seal. [END HIJACK]
