  • July 08, 2025, 04:33:35 PM
Author Topic: B 40 Needle Valve  (Read 787 times)
Offline Allen Eshleman
B 40 Needle Valve
« on: August 04, 2009, 04:31:26 PM »
I am breaking in a new Brodak 40.  I put it on an old profile plane as a test stand.  It starts easily.  I have run it 6 times for 6 1/2 minutes.
However, the needle valve does not stay in one place.  How can I tighten it?
Offline Jim Oliver
Re: B 40 Needle Valve
« Reply #1 on: August 04, 2009, 04:45:42 PM »
There should be/have been a locking collar (nut) for the needle valve which, when installed properly, will allow the N V to be adjusted but retain the selected position by applying pressure to the spraybar into which the N V fits..........
http://www.brodak.com/shop.php?pageNum_ProductInfo=5&totalRows_ProductInfo=93&CategoryID=63
http://www.brodak.com/shop_productdetail.php?ProductID=6277
The bottom link should show a close-up view..........
Cheers,
Jim
Jim Oliver
AMA 18475
« Reply #2 on: August 06, 2009, 06:17:42 AM »
Thanks Jim,
      I tightened it up.  It now has 15 short runs.  Five or so more to go and it will fly.  I have it on a very old "Cosmic Wind for break - in.  The profile format made an easy test stand.  I will fly it there for awhile.  Then it is destined for a Nobler.
