  • June 23, 2025, 01:30:43 AM
Author Topic: OS .35S/Jetstream muffler bolt size ???  (Read 818 times)
« on: March 04, 2014, 08:50:36 AM »
Hi All,
On the older OS .35S engines the muffler mounts are threaded bosses in the ends of the exhaust stack.  I have a few Jetstream mufflers which attach this way.  I need to know the thread and length of the mounting bolts.
Thanks!
BIG Bear
RNMM/AMM
Offline Dallas Hanna
Re: OS .35S/Jetstream muffler bolt size ???
« Reply #1 on: March 06, 2014, 03:17:23 AM »
Bill, from this post http://stunthanger.com/smf/index.php?topic=34488.0 the bolts to hold your muffler on retaining original tapped holes in engine exhaust stack is:
Edit for actual info measured from muffler.
Muffler thickness = 5mm
Extension = 14mm
Tapped hole recessed 12mm into exhaust stack
Tapped hole M2.6 x 0.45 x 5+mm deep
Bolt should be M2.6 x 0.45 pitch x 36 long
Earlier I posted a length of 41 mm long due to another poster giving 1 5/8" long.
HH
« Last Edit: March 06, 2014, 10:06:58 PM by Dallas Hanna »
Offline Geoff Goodworth
« Reply #2 on: March 06, 2014, 04:30:09 AM »
How long do they have to be?
Micro Fasateners lists M2.6 x 6, 8 and 12mm long.
« Reply #3 on: March 08, 2014, 03:27:20 AM »
Hi Geoff,
According to Herbie, they need to be 36mm long.
BIG Bear
RNMM/AMM
« Reply #4 on: March 08, 2014, 04:16:00 AM »
Yes Bill.  :(
When it comes to threads, fasteners, and the like, Herb is more useful than Google. H^^
