  • June 14, 2025, 11:13:16 PM
Author Topic: Atwood .49 gasket sealant  (Read 946 times)
Offline David Campbell
« on: October 31, 2021, 10:04:36 PM »
which sealant would be the best for the crankcase gaskets for an Atwood 49 I tried permashield fuel resistantsealant and it has not worked it leaks
David
Offline Robert Zambelli
Re: Atwood .49 gasket sealant
« Reply #1 on: November 01, 2021, 08:37:33 AM »
David - I have been running the Atwood for over 20 years.
I use the Permatex Anaerobic Gasket maker, part number 51817 (available from Amazon).
It works with glow, gasoline and Diesel fuels.
As a matter of course, I replace the gaskets in ALL my engines with this product and NEVER had a leak.
Clean the surfaces well of all oil, assemble and you're good to go.
« Reply #2 on: November 01, 2021, 06:12:43 PM »
Thank you Robert
