Engine basics => Engine set up tips => Topic started by: David Campbell on October 31, 2021, 10:04:36 PM
Title: Atwood .49 gasket sealant
Post by: David Campbell on October 31, 2021, 10:04:36 PM
which sealant would be the best for the crankcase gaskets for an Atwood 49 I tried permashield fuel resistantsealant and it has not worked it leaks
David
Title: Re: Atwood .49 gasket sealant
Post by: Robert Zambelli on November 01, 2021, 08:37:33 AM
David - I have been running the Atwood for over 20 years.
I use the Permatex Anaerobic Gasket maker, part number 51817 (available from Amazon).
It works with glow, gasoline and Diesel fuels.
As a matter of course, I replace the gaskets in ALL my engines with this product and NEVER had a leak.
Clean the surfaces well of all oil, assemble and you're good to go.
Post by: David Campbell on November 01, 2021, 06:12:43 PM
Thank you Robert
