  • June 21, 2025, 03:43:41 PM
Author Topic: Older Max-S question  (Read 1221 times)
Offline rich gorrill
« on: February 04, 2015, 04:18:05 AM »
Quick question about Max=S 35 with a carb. Will the newer venturi's for the L.A. and F.P. fit to convert to control line. Also will the newer needle's work.
T.I.A.
Rich
Re: Older Max-S question
« Reply #1 on: February 04, 2015, 09:33:33 AM »
Hi Rich,
No, you will have to get one made for the "S".  The newer NVA also has a smaller OD.  Several sources for a venturi, check the Vendor's Corner.  I know Randy Smith and Jim Lee both supply then.
BIG Bear
RNMM/AMM
« Reply #2 on: February 04, 2015, 04:03:29 PM »
Thanks Bill
« Reply #3 on: February 04, 2015, 09:31:44 PM »
The Olde OS max 20 & 25 venturie fit , they ( sometimes ) came with THREE . Bigger ones just smaller than std. .35 sucker .
SEARCH here gets a bit of info on prefered sizes .
a nice long nylon ones likely to run more even .
