Engine basics => Engine set up tips => Topic started by: rich gorrill on February 04, 2015, 04:18:05 AM
Quick question about Max=S 35 with a carb. Will the newer venturi's for the L.A. and F.P. fit to convert to control line. Also will the newer needle's work.
T.I.A.
Rich
Hi Rich,
No, you will have to get one made for the "S". The newer NVA also has a smaller OD. Several sources for a venturi, check the Vendor's Corner. I know Randy Smith and Jim Lee both supply then.
BIG Bear
RNMM/AMM
Thanks Bill
The Olde OS max 20 & 25 venturie fit , they ( sometimes ) came with THREE . Bigger ones just smaller than std. .35 sucker .
SEARCH here gets a bit of info on prefered sizes .
a nice long nylon ones likely to run more even .
