  • June 21, 2025, 08:23:14 AM
Author Topic: Need good wood props ?  (Read 1051 times)
Offline Rob Killick
« on: July 17, 2007, 07:03:10 AM »
Hi ,
After I break in my Brodak .25 , I need help choosing a good wooden prop for it and my Brodak "FancyPants".
I don't have an all-up weight for the ship , so I hope this doesn't cause a problem in selecting a prop for it ?
Thanks in advance  ;D
Rob Killick , MAAC 33300
Offline Jerry Bohn
  • ACE
Re: Need good wood props ?
« Reply #1 on: July 17, 2007, 12:51:45 PM »
Rob, I have found on my Barnstormer with OS25LA that a Zinger 9x5 works great for my combination. Good as any place to strart. 9x6, 9x4 will also work depending on all your planes fuel, weight, and altitude that you fly at.
I'd get what ever is avaliable the quickest, and quickly go flyin.
Have fun, working out the right prop is part of trimming a plane.
Jerry Bohn
Offline Jim Oliver
« Reply #2 on: July 17, 2007, 01:55:12 PM »
Hi Rob,
On the Flite Streak ARF/Brodak 25 combo, I used an APC 9x5 with good results.  The APC brand was used to avoid adding nose weight.
The 9x5 Zinger should be fine.
Jim
Jim Oliver
AMA 18475
« Reply #3 on: July 17, 2007, 06:13:21 PM »
Rob:
You said wood props?  I've had nothing but great luck with Top Flite PowerPoints - I'd suggest a 9-5 for the B.25 & SC.  I am running that prop on my SC now...
Also agree that you could try a 9-4, 9-6 or even a 10-4 depending on what you are looking to achieve...
Offline Rob Killick
« Reply #4 on: July 17, 2007, 09:10:09 PM »
Thanks for the help fellas :)
