  • June 21, 2025, 04:59:44 PM
Author Topic: Fox 59 setup question  (Read 901 times)
Offline don Burke
« on: April 07, 2007, 09:20:37 PM »
Hi All,
I just got an nicely used FOX 59 front intake intending to use it in an OTS (long term in the future project).  It is however an R/C model with the venturi cut off.
I will make a venturi for it, but, does anybody have an idea what the original venturi diameter happened to be.  And is that diameter good for stunt.  The NVA that came with it is FOX but has a turned down diameter of .145 where it would be in the venturi.  Is this normal for the 59?
Thanks in advance.
don Burke AMA 843
Menifee, CA
Re: Fox 59 setup question
« Reply #1 on: April 08, 2007, 07:37:23 AM »
On my RC versions I used a .292 opening and a ST needle valve
Offline don Burke
« Reply #2 on: April 08, 2007, 08:49:33 AM »
Thanks, sounds about the size of a current 46, which should equate.
don Burke AMA 843
Menifee, CA
Offline Ralph Wenzel (d)
« Reply #3 on: April 16, 2007, 01:36:08 AM »
Yep, about right, except you don't yet know what loud is!  Plan on a 13-6 prop, or thereabouts. Should do the pattern on 5 - 5½ ounces of fuel.
Ralph Wenzel
AMA 495785 League City, TX
Offline don Burke
« Reply #4 on: April 16, 2007, 09:34:16 AM »
I definitely plan on using some kind of muffler.  I wish everyone would use something, it's one of my pet peeves about speed and racing too much noise, but I also realize it's part of the mistique!
don Burke AMA 843
Menifee, CA
