  • August 04, 2025, 06:27:21 AM
Author Topic: Acetone in ultrasonic cleaner?  (Read 1763 times)
Offline frank mccune
« on: November 15, 2020, 02:48:07 PM »
     Hello All:
     Will acetone work well in an ultrasonic sleaner?
     Tia,
      Frank
Re: Acetone in ultrasonic cleaner?
« Reply #1 on: November 15, 2020, 03:54:51 PM »
Frank.  Not necessary.  Ultrasonic cleaners work by the vibrations of water molecules on the part immersed.  Normally, water with  soap or detergent is used, mostly used to wash away the loosened particles.   Acetone or paint thinner is just too dangerous. and probably not any better than soap.
Offline Lauri Malila
« Reply #2 on: November 15, 2020, 03:57:59 PM »
You can use acetone in ultrasonic cleaner, but take good precautions because it's stinky and volatile.
I recommed to put the acetone in as small jar as possible, glass or plastic, to house the part you're cleaning and immersing the jar in the US filled with warm water.
But don't expect miracles, in case you want to clean that dried castor you mention in the other thread. It may loosen up but it also may dry the residue to an even harder sediment. L
