  • July 11, 2025, 08:41:08 PM
Author Topic: ? about Max-S 30 & 35  (Read 1510 times)
Offline rich gorrill
« on: April 22, 2016, 02:26:38 PM »
Hello all I hope someone can help me with a question. I have a Max-S 30 with a worn out rod. Can I use the rod from a Max-S 35 to replace it. I don't know if the difference between the two engines is the bore or the stroke.
T.I.A.
Rich
Re: ? about Max-S 30 & 35
« Reply #1 on: April 22, 2016, 03:01:57 PM »
Common problem with both .30S and .35S. You can convert a .30S to a .35S, so I'd bet the rod would be the same. There are (or were) bushed aftermarket rods available. Ask Leonard Neuman, Randy Smith or Brian Gardner, and maybe use more castor oil than you have been!  y1 Steve
Online RandySmith
« Reply #2 on: April 22, 2016, 03:22:30 PM »
T.I.A.
Rich
Yes you can, I have stock rods and better  hard aluminum rods for these engines
« Reply #3 on: April 22, 2016, 04:56:04 PM »
Thanks Randy.
Rich
