  • June 17, 2025, 07:11:54 PM
Author Topic: HP .40 SS front bearing seals?  (Read 1247 times)
Offline frank mccune
« on: October 22, 2020, 10:51:31 AM »
      Hello:
      Should I leave the seals in or remove one or both?
      Tia,
      Frank
Offline BillP
Re: HP .40 SS front bearing seals?
« Reply #1 on: October 22, 2020, 11:18:06 AM »
I make no claim to be an expert engine person but the front seal is alleged to keep dirt out and the rear seal removed for lubrication. In my experience using a front seal on two 60 size rc engines has resulted in shorter bearing life (compared to many others without front seals).
Bill P.
« Reply #2 on: October 22, 2020, 11:28:51 AM »
      Hello:
  Remove one seal and install the bearing with the remaining seal in front.
