  • June 17, 2025, 01:51:12 AM
Author Topic: Lean in outsides and inverted  (Read 1332 times)
Offline Dwayne Donnelly
« on: July 21, 2020, 03:54:09 PM »
Hi guys, in general if an engine is going a bit lean in outsides and inverted do I raise or lower the tank.
Thanks  y1
Re: Lean in outsides and inverted
« Reply #1 on: July 21, 2020, 04:46:04 PM »
Thanks  y1
   Lower.
« Reply #2 on: July 21, 2020, 06:02:19 PM »
Thanks, kinda embarrassing I really should remember this stuff...lol Anyway I was gifted this beautiful T-Bird with a enya 29, I'm using a Brodak uniflow tank that is on the engine beams, due to the cowl  I might not have room to shim the engine, if not it means somehow shaving the beams, any ideas?
Offline Peter in Fairfax, VA
« Reply #3 on: July 21, 2020, 06:41:28 PM »
It will be interesting to see what others suggest.  I'd go with taking a dremel to it and gouge out a lower home for the tank, then possibly sister on some more beef to the beams if you end up taking a lot.  Is that a balsa floor between the tank and beams?  That could be the first to go.
« Reply #4 on: July 21, 2020, 06:57:40 PM »
No the tank is on the beams.  :-[
« Reply #5 on: July 21, 2020, 08:07:30 PM »
   Open up the tank and move the uniflow vent lower.
Online Massimo Rimoldi
« Reply #6 on: July 21, 2020, 11:58:46 PM »
IF what you need is very little and you have the hole of the NVA in A position of the drawing, you can turn the NVA and bring the hole in B position .
Massimo
« Reply #7 on: July 22, 2020, 07:16:46 AM »
Interesting ideas.
The custom tank with lower pickup / vent might just work.
Moving the outlet of the NVA also might work.  Depending on how much movement is needed, arranging where the hole in the venturi goes by drilling a new hole in the venturi itself could be considered, perhapos combined with tapping the case for a set screw.
« Reply #8 on: July 22, 2020, 07:35:39 AM »
That should do the trick.
Thanks Bret
 y1 <= #^
Offline John Leidle
« Reply #9 on: July 22, 2020, 08:03:36 AM »
   When all else fails I would " consider " raising the engine  or making a thinner tank.
           John L.
« Reply #10 on: July 22, 2020, 08:31:35 AM »
Curious as to why moving the vent is suggested vs. moving the pickup.
« Reply #11 on: July 22, 2020, 08:49:49 AM »
Moving the uniflow  vent up or down will effect your engine run, I set my clunk tanks up the same way, that way you don't have to raise or lower the tank you simply move the uniflow tube up or down, I thought about using a clunk tank for the T-Bird but didn't have enough room.
