  • June 22, 2025, 12:04:35 AM
Author Topic: Mini pipe muffler for VF46  (Read 1160 times)
« on: March 29, 2008, 10:22:56 PM »
Has anyone found a good mini pipe rear exhaust muffler set up for the VF46? I have run this with a full pipe but would like to use a set up with a short RE muffler any options?
Best,   Dennis
Online James Mills
Re: Mini pipe muffler for VF46
« Reply #1 on: March 29, 2008, 10:57:21 PM »
I have a rear muffler for my VF 40 that's going in my Formula S that Byron Barker made for me (got the idea from Allen Brickhaus).  He made if from a header for the pipe.
James
AMA 491167
Offline Greg L Bahrman
« Reply #2 on: March 30, 2008, 08:34:18 PM »
Randy Smith might be able to help you as he makes them for all his other motors.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
« Reply #3 on: March 31, 2008, 09:33:16 AM »
Randy Smith (a moderator and Aero Products has what you need!  Either "header mufflers" (one piece) or can mufflers that attach to the Header (which are a little more quiet).
« Reply #4 on: March 31, 2008, 09:53:59 AM »
Best,   Dennis
Hi Dennis
I think these maybe what you are looking for, I also make them for  VF engines
« Reply #5 on: March 31, 2008, 04:06:41 PM »
Randy,
Is there any special mods needed on the VF's (40 or 46) such as adding head gaskets or changing venturi size from the full pipe setup to get this to work? Once set up for the 46 what would be a good starting setup for prop, venturi, head gaskets and fuel nitro.
Thanks,       Dennis
Offline Jim Oliver
« Reply #6 on: March 31, 2008, 06:19:32 PM »
Yeah, Randy.....
I need to know the answer to this one, too!!
Jim
Jim Oliver
AMA 18475
« Reply #7 on: March 31, 2008, 08:44:57 PM »
Randy,
Thanks,       Dennis
Hi Dennis
The OS VF 46, works fairly close to the same using the slide on tube muffler, just add about 1/4 pitch up on the prop, if using  the  header muffler you typically need to add the 1/4 more pitch and go up a size on the venturie.  you will not need to add a head shim.
WE use a 12.2 x 4.2  2 blade  or  a  12 x 4.25 3 blade on the 46, these run at about 4 1/2 on mufflers for the 46.
As  alway  you should use the amount of nitro that the engine need depending on the air conditions
