  • June 22, 2025, 09:14:34 AM
Author Topic: 4 Stroke for CL  (Read 1385 times)
Offline David_Ruff
  • David Ruff
  • Retired Army
4 Stroke for CL
« on: February 08, 2014, 06:49:17 PM »
Speaking of engines, I saw a photo of a Ringmaster with a 4 stroke engine mounted.
Any ideas on using 4 stokes for CL?  Most of what I see are RC engines.
Just glad to be here
Re: 4 Stroke for CL
« Reply #1 on: February 08, 2014, 07:06:00 PM »
   There is a rather extensive forum for exactly that. They work quite well, and had bursts of popularity in the mid-80's and later the early 2000s.
Offline David_Ruff
  • David Ruff
  • Retired Army
Re: 4 Stroke for CL
« Reply #2 on: February 08, 2014, 07:07:37 PM »
Is that forum here?  I am interested in trying that.
Offline Paul Wood
Re: 4 Stroke for CL
« Reply #3 on: February 08, 2014, 07:31:02 PM »
David,
Go to the forum home page and you'll find 4 strokes under the "engine" section.  Lot's of info to keep you busy for a while.
Offline 55chevr
Re: 4 Stroke for CL
« Reply #4 on: February 08, 2014, 07:37:39 PM »
A lot of us are flying 4 strokes ...
Joe Daly
Offline David_Ruff
  • David Ruff
  • Retired Army
Re: 4 Stroke for CL
« Reply #5 on: February 08, 2014, 07:38:34 PM »
I went to the forum.  Thanks
Offline Martin Quartim
    • StuntHobby
Re: 4 Stroke for CL
« Reply #6 on: February 09, 2014, 10:12:05 AM »
Yes 4 stroke engines works really well for C/L. The Chinese WC Team use Saito 4S exclusively.
The Saito 40 is a jewel, lighter then most 2 Stroke .40s and has torque to swing a 12x6.
Martin
Walter Hicks
Re: 4 Stroke for CL
« Reply #7 on: February 09, 2014, 10:28:21 AM »
I  am currently using Saito 62 in one plane and will use Saito 40 in another. Make sure you look up the name Bob Reeves and do what he says.
for $40 he will modify your Saito Carb to work perfectly for what we want in stunt. Learn how to adjust your needle setting as it is much different than
2 stroke. The disadvantage is that the 4 strokes shake a lot. So make sure and build the front end well on your plane. They weigh more that most
2 stroke also so make the nose shorter on  your plane. If you are not going to use Ro Jett ,or PA, or Electric this will provide you
lots of steady power when it is set up correctly( See Bob Reeves information and Tulsa Glue Dobbers Web Site). Correct fuel, carb and glow plug
prop,you use venturi size to adjust the rpm. 8200-8500. Props that load the motor. I use them on semi scale planes that are draggy
and maby heavier that I like them to be. You can use big props also.
<a href="http://s82.photobucket.com/user/kickercoach12/media/IMG_0418.jpg.html" target="_blank"><img src="http://i82.photobucket.com/albums/j262/kickercoach12/IMG_0418.jpg" border="0" alt=" photo IMG_0418.jpg"/>[/url]
Offline 55chevr
Re: 4 Stroke for CL
« Reply #8 on: February 09, 2014, 06:30:41 PM »
Once I set the Saito 40 to the desired lap time (5.3) with Reeves carb I haven't had to touch the setting ... consistently the same day after day.
Joe Daly
