  • July 11, 2025, 05:02:23 PM
Author Topic: muffler pressure  (Read 1225 times)
Offline Bootlegger
muffler pressure
« on: January 11, 2011, 01:33:33 PM »
 H^^     Fellow's where is the best spot to put a pressure tap in the muffler of a RO Jett engine, it is rear exhaust, and I'd like to try muffler pressure..
   Thanks a lot, Gil     :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: muffler pressure
« Reply #1 on: January 11, 2011, 03:10:29 PM »
If it is a header type muffler put it near the back of the tube
If it is an expansion chamber muffler, it will not make much differance where you put it
Offline Joe Mig
« Reply #2 on: January 12, 2011, 04:54:46 AM »
While on the subject if you don't mind .
On a tank what is the best tube to put it on the top fill or bottom overflow tube ?
« Reply #3 on: January 12, 2011, 08:28:46 AM »
Hi Joe
I found it is best on a uniflow tube, If possible I would use a uniflow tank, If not possible I would use the bottom overflow tube
Offline Joe Mig
« Reply #4 on: January 12, 2011, 08:54:04 AM »
Hello Randy; I think I'm using a uniflow tank .
So witch is the uniflow tube ?
Thanks for the help.
Joe
« Reply #5 on: January 12, 2011, 10:51:14 AM »
Joe
The uniflow is the tube you would be filling the tank through..if it is a uniflow tank
If it just has a tube straight out of the top and a tube straight out of the bottom it maybe a standard vent tank?
